VideoHelp.com Forum
  1. Somehow I managed to inadvertently lock the disk tray on my SD-V295 dvd/vcr combo unit (the padlock icon is displayed), & I can't unlock it. I've tried unplugging the player (for 24 hours!), tried "setup-2-0-0-5-setup", tried holding the open/close button in.....ahhh, I've tried a thousand different methods with no luck. Do any of you guys know of a code/sequence that can unlock this damned tray?
    Edit 1-19-09:
    Solved! A Toshiba customer rep had me try this sequence of buttons on the remote: setup-subtitle-3-audio-0. It didn't work...until I finally got disgusted & opened the beast up. In the upper right corner of the small circuit board atop the drive, there are 2 thin ribbon connectors; I unplugged the one furthest from the front of the unit, plugged in the AC, & pressed the open/close button. The tray opened - BUT - after putting it all back together & powering up, I still saw the dreaded padlock icon, & had a locked tray. However, THIS time when I tried the above sequence, the closed padlock icon was replaced by the OPEN padlock icon! Tray unlocked! Success!!
    Stiiv
    ok, the sequence worked, but every time I use a CD and press stop and turn off and turn on i have a locked tray.someone knows how to fix that permanently..
    Help me please!!!
  1. Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
    By renavspainatal in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 5th Nov 2009, 08:59
  2. Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
    By daveshostack in forum DVD & Blu-ray Players
    Last Post: 12th Feb 2008, 11:41
  3. Toshiba SD-3990 DVD Player Tray Will Not Open
    By TufrThanu in forum DVD & Blu-ray Players
    Last Post: 22nd Aug 2007, 02:35
  4. LG DVB418 Tray locked shut!
    By ness395 in forum DVD & Blu-ray Players
    Last Post: 10th Jul 2007, 16:53
  5. Replies: 2
    Last Post: 27th May 2007, 17:52
