VideoHelp.com Forum
    Hi,
    I have a bunch of pre-recorded PAL Hi8 video tapes that I want to transfer to DVD. I have a PAL DVD-recording deck, but no PAL Hi8 camcorder.
    If I use an NTSC camcorder to play the PAL tapes, will the output also be PAL? That way I could use my PAL DVD recorder, and all is well in the world.
    In other words, does the NTSC/PAL designation on analog camcorders/vcr's only refer to how the device RECORDS tapes, and it just outputs whatever format the tape was recorded in? (That would mean that I could use an NTSC VCR deck to play back PAL tapes as long as I had a PAL TV to view the image on).
    Or is it just plain impossible to play a PAL tape on an NTSC machine and get useful output, of any kind, be it NTSC or PAL?
    thanks!!
    -- interlooper
  2. Member hech54's Avatar
    Originally Posted by interlooper
    Hi,
    thanks!!
    -- interlooper
    I'm afraid you answered your own question.
    You'd have a chance with a PAL camcorder....a slight chance. Some DVD Recorders
    will record in either format via RCA or S-Video....they just have a nasty reputation
    for not advertising this feature. My old Philips records both NTSC and PAL to a virgin/blank disc.
  3. Member edDV's Avatar
    Generally NTSC DV camcorders will not play PAL DV tapes. This is on purpose to prevent trans-shipment.
    You may see some prosumer DV camcorders with PAL tape play feature but this only works to the camcorder LCD, not out the Firewire port. You need to get up into the true multi-standard DVCPro camcorders (>$10k used).
    So use E-Bay and find a used PAL model or shop an International Duty Free shop in big cities. Some of the NYC camera shops sell PAL models online.
    http://www.kiva.org/about
  1. PAL Hi8 Analog Blank Tapes needed
    By SGGS in forum Newbie / General discussions
    Last Post: 1st Dec 2011, 11:57
  2. 8mm tapes PAL with NTSC camcorder????
    By igorv in forum Capturing
    Last Post: 11th Oct 2010, 13:17
  3. PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
    By quantass in forum Newbie / General discussions
    Last Post: 12th Dec 2008, 13:47
  4. ntsc tapes pass through pal camcorder into mac for ntsc playing?
    By tozier9 in forum Newbie / General discussions
    Last Post: 7th Dec 2008, 17:19
  5. PAL VCR with true NTSC Output (not PAL 60)
    By Area88 in forum Restoration
    Last Post: 12th Aug 2008, 17:55
