How do I hook up my toshiba dvd/vcr with samsung plasma tv and comcast hd box? Here is the backpanel of the comcast hd box except it is not a dvr http://broadband.motorola.com/consum...t6208_back.jpg. I have a toshiba Toshiba D-KVR20ku dvd/vcr recorder and a samsung plasma pn42a450p1d. I have hd picture, can view dvds and vhs tapes. I can record picture but get no sound.
Results 1 to 9 of 9
I would run DVI/HDMI directly from the cable box to the TV along with digital audio. Then run s-video or composite (yellow RCA) and stereo audio (red and white RCA) from the cable box to the VCR/DVD combo for recording to VHS. Run s-video or composite from the VCR/DVD to the TV for VHS playback. Finaly HDMI or component from VCR/DVD to TV for DVD playback.
This box does not have hdmi port only componet out.
Use component for your tv,1080i is the best you can get anyway.Originally Posted by ranger_cole
BTW:that's probably an old photo because all of the Motorola HD boxes Comcast uses now have HDMI.
The picture shows DVI and what appears to be an optical audio out (between the s-video and firewire connectors). You can use a DVI->HDMI cable and an optical audio cable to go from the box to the TV (if the TV has optical audio in). That should look slightly better than component, your next choice.
Maybe an old photo but that is the box they are giving out in murfreesboro tennessee as of 1/16/09.
I went from bottom red and white out of hd cable box to vcr/dvd in. From vcr/dvd out to the componet 1 of the tv. I the went from dvd red and white out to the composite on the tv. I can record with sound on the DVD side. I may need to switch the red and whites to get the vcr to record with sound.
Nevermind.
That box is fine for DVI-D to HDMI for Samsung HDTV (HDCP required and supported).
http://www.kiva.org/about
Look what I found-a Motorola DCH3200 set-top box for use with Comcast cable
By zoobie in forum DVB / HDTVReplies: 7Last Post: 15th Dec 2010, 20:27 -
Will my store-bought DTA box do the same thing as a Comcast DTA box?
By locust78 in forum DVB / HDTVReplies: 5Last Post: 20th Oct 2009, 16:12 -
Failure to record from Comcast feed
By DVD Curious in forum Newbie / General discussionsReplies: 1Last Post: 8th Oct 2009, 13:18 -
Connecting an lcd to a comcast tv box?
By Gplracer in forum DVB / HDTVReplies: 0Last Post: 10th Aug 2008, 20:58 -
Record HD from a Comcast DVR?
By elister in forum DVB / HDTVReplies: 15Last Post: 10th Dec 2007, 17:11
