Hello,
I have a WD Elements 500 HDD http://www.wdc.com/en/products/Products.asp?DriveID=333, which has 8 folders ( named 2007,2006....,2000). In each of these folders, there are almost 100 DivX movies.
I have connected this HDD to my DVP 5980.
The problem is that the player does not show the contents of some folders. In other words, the folders 2004,..2000 are being shown empty. whereas, the contents of other folder are accessible and fine.
Is it a problem from player or from HDD ? Any solution ?
800 files is too much 668 (citation needed) is max number of files.. see website for max folders, max files...get a WD HD TV instead, max no files 2 to the power 42, more files than atoms in the observable universe. 8)
http://www.wdc.com/en/products/products.asp?driveid=572
Be interesting to see how it decides which files to show..creation date? place in fat table?
From Manuel "The unit can only support up to a
maximum of 300 folders and 648 fi les."Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
I do not have this player, but in a thread a few weeks ago someone asked about file and folder limits on this same player. When I suggested that 648 was a total file limit, I was rebuked by one of the old forum hands and told that it was 648 files per folder. How very interesting that I seem to have been right about this being a total file limit and not a per folder limit.
Philips DVP 5990 and the external 2,5" HDD PQI H560 500GB - will it work?
By tompalo in forum DVD & Blu-ray PlayersReplies: 11Last Post: 16th Mar 2010, 10:43 -
Philips DVP 5990/37 HDD issue - need help
By badboo in forum DVD & Blu-ray PlayersReplies: 8Last Post: 20th Feb 2010, 14:27 -
philips 5980 vs 3980
By 45tripp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2008, 16:38 -
Philips 5980 firmware hack ???
By Milo Mills in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th May 2008, 10:48 -
Problem with Philips DVP 5980/12
By Tinah in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Dec 2007, 11:57
Statistics
Newest guides
Latest tool updates
New media comments
