VideoHelp.com Forum
    Just curious as to whether its possible or even desirable to use bog standard DV AVI footage (which is of good quality), convert that to 1080p, burn and view via Blu Ray on a widescreen Plasma TV? If so, which codec, tool would people use for conversion?
    Yes, it's possible but not worth it. Get a HD camcorder instead.
    It's possible but the result will be pretty much the same as displaying the original DV AVI footage directly on the HDTV.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    You could try XviD4PSP or RipBot264 and see if they will work for that. Are you planning to use a Blu-ray burner and disc or do you just want to use the AVC/H264 format on a regular DVD disc for a Blu-ray player?
  5. Member edDV's Avatar
    possible? yes
    desirable? no
    Instead encode to a high quality SD interlace MPeg2 and let the player do the upscale. Keep the DV originals.
    PS: I'm not sure of the maximum SD MPeg2 bit rate for Blu-Ray but I'd bet it is over ~9Mb/s maximum for DVD. You could try 20Mb/s for very high quality.
    http://www.kiva.org/about
  1. Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
    By brad350 in forum Newbie / General discussions
    Last Post: 21st Apr 2012, 04:15
  2. Blu Ray 720p vs 1080p
    By zork152 in forum Newbie / General discussions
    Last Post: 11th Jan 2010, 11:32
  3. Blu-ray (1080p) menu template .PSD? Anyone got one?
    By Asterra in forum Authoring (Blu-ray)
    Last Post: 18th Jul 2009, 16:50
  4. x264 1080p blu-ray files
    By eric11111 in forum Authoring (Blu-ray)
    Last Post: 7th Dec 2008, 09:48
  5. I recorded in 1080p 29 f/s with a HD camcorder. Burn it to blu-ray or dvdr?
    By templedog in forum Newbie / General discussions
    Last Post: 25th Nov 2008, 11:37
