VideoHelp.com Forum
    I just compressed a couple blu-rays and now they do not fast forward or rewind. Is that supposed to work that way??
    When I initially remuxed with tsmuxer I unchecked the timing and insert sps/pps, or whatever, I was under the impression that I should do that. I don't know if that has anything to do with it, I think it must be the compression though, that's a drag, anyway around this??
    thanks,
    rlr
    Maybe try compress using bd rebuilder?
    I assume you are doing this with the common freeware methods. This is common if you are playing from a disc, and may vary with the particular standalone unit model & firmware version.
    If you want complete compatibility it costs a lot of $$ (~$10K) for a professional encoder/authoring suite like Sonic Cinevision+Scenarist, but compatibility will be much better. It would be a lot cheaper just to buy a few blu-rays for backup
    There are several threads at Doom9 forums discussing this topic if you want more information.
    Yeah, but I can't remove trailers and extras with BD-RB though, right? and you can't use any size output with it yet, you are relegated to 3 choices, looks like he is in the process of changing that, but will prob have to wait for another revision or two.
    thx
    I actually have a copy of Sonic Scenarist, and have briefly checked it out, but was a bit overwhelmed. It will do what I want? will it keep menus intact also? I'll have to look at it again, it's much more complicated than your regular commercial fare.
    btw I found if i took the compressed x264 file and then remuxed with original audio, with tsmuxer, to BD, and left insert pic timing, and sps/pps(?) boxes checked, the movie will then RW and FF (at least as well as it did in the first place anyways, RW still is awful, idk if it's my player or what).
    rlr
    I don't have scenarist, so let us know when you figure it out ok
    IIRC, the issue is with x264, not the authoring. It is with how it handles slices. So scenarist (which just authors), and bd-rebuilder won't help (because it uses x264). Apparently some standalone units are more prone to this problem than others
  1. Replies: 29
    Last Post: 23rd May 2012, 05:06
  2. Problem converting blu-rays
    By RumeredoTR in forum Video Conversion
    Last Post: 29th Apr 2010, 21:05
  3. anybody knows those blu-rays brands?
    By angel40204 in forum Media
    Last Post: 6th Oct 2009, 18:00
  4. Can i use a blu-ray reader to Rip my Blu-rays ?
    By fairwind in forum Newbie / General discussions
    Last Post: 29th Nov 2008, 11:04
  5. can i use a blu-ray reader to rip my blu-rays?
    By fairwind in forum DVD & Blu-ray Writers
    Last Post: 28th Nov 2008, 13:08
