I have an mpg file which is 2 GB. It is PAL format, it was recorded in SP mode so its a 1 hour long video. I converted it to divx with Gordian Knot and it lasted 4 hours! Is that normal???
My PC is AMD Athlon 1.84 GHz, 768 mb of ram
I made a divx which is 700 Mb, resized to 640x480.
Results 1 to 9 of 9
It takes me on a 2.0GHz machine 6 hours or so for about a 2hr MPEG. Always been that way for me. I do Xvid 640x480 and select one of the preset sizes so its 2-pass.
Originally Posted by szalaikornel
Well I tested everything. I used the same mpg file of 2GB, the same version of Auto Gordian Knot and the conversion to divx (640x480) lasted about 4 hours on my pc and 1 hour 40 minutes on friend's PC.
My PC is 1.84 GHz his is also! My RAM is 768 mb, his is 1 GB. This is the only noticable difference between our pc's.
k-lite codec pack and divx7 is installed on both computers. I really dont know why is converting to divx on my pc so slow. -
You used AutoGK for this test? Then please post the log.
But again, you can't really compare the 2 computers. Maybe you have a bunch of crap running in the background using all your computer resources while his is "clean". Do a Ctrl-Alt-Delete and check what's using your RAM. Check what loads on startup and uses RAM. Maybe you don't even have any RAM available after the computer boots up. -
Error with Auto Gordian Knot 2.55
By Salvus in forum Video ConversionReplies: 1Last Post: 2nd Nov 2009, 06:51 -
Auto Gordian Knot, a/v out of sync
By takearushfan in forum Newbie / General discussionsReplies: 13Last Post: 22nd Feb 2009, 13:08 -
Double titles in Auto Gordian Knot and other programs
By blerk2505 in forum Video ConversionReplies: 2Last Post: 8th Nov 2008, 19:33 -
Auto Gordian Knot Hidden Options Error
By Mabbage in forum DVD RippingReplies: 1Last Post: 18th Aug 2008, 14:59 -
Auto Gordian Knot anyone?
By Lee82 in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 20:31
