This is probably a common problem, sorry I haven't been able to find a solution in the searches.
I have a 50min avi file of around 500MB and after editing a clip of about 5 mins resulted in a size of more than 8GB. I used Virtualdub for editing. Is this always the case and needs one to do some compression afterwards, or can this be avoided?
If you are just cutting/joining then choose Video->Direct Stream Copy and Audio->Direct Stream Copy and the file size should not increase. But if you are adding some filters then must you choose a compression if you want smaller file size, Video->Compression and choose a codec like xvid or divx. You are now saving it as UNCOMPRESSED video and that is huge.
Trying to Fix a Huge Corrupt .avi File!
By LPrime in forum Software PlayingReplies: 33Last Post: 17th Apr 2012, 05:01 -
I need to edit a huge .avi file
By Hobittual in forum EditingReplies: 2Last Post: 25th May 2010, 15:40 -
Huge AVI file after mencoder encoding
By nickman00 in forum DVD RippingReplies: 3Last Post: 2nd Jun 2009, 18:57 -
Huge file after WMV to AVI conversion
By windranger in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2008, 07:32 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 17:31
Statistics
Newest guides
Latest tool updates
New media comments
