Dear Friends,
There are 2 problems regarding DVD Shrink please read in details then reply.
i am using Vista 32 Bit Operating System, i have installed SVCD2DVD 2.5.5020 and DVD Shrink 3.2.0.15
when i make movie throuh SVCD2DVD its going good, but when its completed the project and going to
DVD Shrink program have this error (SVCD2DVD).
Version: SVCD2DVD 2.5
Build: 2.5.5020.0
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
After that i have open standalone DVD Shrink when use option Re-Author, program closed.
After that i have chnage the compatibilty mode to prior versions of opertaing system like "windows 98, Me"
at this program option Re-author run successfully but when i click open files option from dvd shrink it
didn't show/open my folder and files
please send me the solution of 2 problems i am waiting
i am very greatfull to you
regards
Vista Sp1 32-bit
SVCD2DVD 2.5 Build: 2.5.5020.0
DVD Shrink 3.2.0.15
Just tried to author a DVD tonight which required the Shrink step. I experience the same error -
Build: 2.5.5020.0
Source: SVCD2DVD
InnerException:
The error occurs after SVCD2DVD creates the DVD folders and is starting DVD Shrink -
18:47:27: Finalising DVD...Done
18:47:27: Done: Authoring DVD Folders
Shrinking with DVD Shrink
***Error here ****
The preshrunk DVD folder was created correctly by SVCD2DVD, so I just opened DVD Shrink myself and ran through the shrinking process. Then burned the resulting DVD with ImgBurn.
Would be nice to get this to work automatically again.
Nevermind - I found the solution.
I did not have SVCD2DVD set to "Run this program as an Administrator." After setting this, DVD Shrink ran just fine.
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
dvdshrink issue
By p71rock in forum DVD RippingReplies: 10Last Post: 1st Sep 2009, 15:52 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
Still Having DVDshrink Problems
By malleus in forum Newbie / General discussionsReplies: 1Last Post: 11th Oct 2007, 15:55
Statistics
Newest guides
Latest tool updates
New media comments
