Hi Folks,
I have a bunch of videos of 720 X 560 resolution videos. All these videos are already compressed. The size of each video is around 40 MB to 50 MB.
Now i want to convert these videos into 640 X 360 (Wide Screen) Videos without losing the quality.
Now i am able to convert them using Virtualdub. But when i use no compression, the output video is rounding more than 5 Gigs.
When i use a compression technique like MSU the output is around 500 MB , quality is good. No loss of quality.
When i use a compression technique like DiVx and FfdShow, the file is around 40 - 50 MB but i am losing great amount quality??
Can anyone suggest a better solution for my problem.
I want the files to remain of the same quality and of same size.
Thanks a lot,
Candyman
It doesn't work that way. They won't remain the same quality no matter what you do and what size you give them (unless using a lossless codec, such as Lagarith, with a huge resulting size). When using very lossy codecs such as DivX or XviD, the quality loss is often noticeable.I want the files to remain of the same quality and of same size.
Converting videos for playback directly on Xbox 360...
By kevinmd88 in forum Video ConversionReplies: 3Last Post: 17th Aug 2011, 23:09 -
How to convert videos for Xbox 360
By xtrattitude4u in forum User guidesReplies: 0Last Post: 27th Nov 2010, 00:17 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 08:12 -
Help encoding 360 x 360 videos (spherical movies)
By sapojow in forum Video StreamingReplies: 29Last Post: 1st Aug 2009, 19:23 -
Would 640 X 272 to 720 X 400 be correct?
By hydrophonicaudio in forum MacReplies: 19Last Post: 24th Jul 2007, 10:33
Statistics
Newest guides
Latest tool updates
New media comments
