VideoHelp.com Forum
Results 1 to 25 of 25
    hello, is out there a tool that convert Sony AVCHD(.m2ts) to a nice .avi (XviD-AC3) I would like to have my clips ripped like those DVDRips on torrent sites... (like: RocknRolla.DVDRip.XviD-DiAMOND if you know what I mean)
    tnx!
    I would try Xvid4psp. Install ffdshow and avisynth and then try to load your m2ts files in xvid4psp. Convert to avi xvid with ac3. Choose the AVI Hardware profile if you want it to work on divx dvd players.
    which denoise/sharpen shuld I use?
    and it says you dont have YV12 decoder! It's need for source interlace detraction.
    tnx, I installed it but still getting same error massage. What should I do?
    make sure h.264/avc is enabled in the ffdshow configuration (set to libavcodec instead of disabled), and haali media splitter installed
    I did everything but still the same error, hmm some tricky stuff...
  8. Member Soopafresh's Avatar
    As much as I like Xvid4PSP, I've never had much luck converting AVCHD files from camcorders with it. Are your M2TS files from a Sony camcorder?
    yes...
    haw do you overcome that problem?
  11. Member Soopafresh's Avatar
    No easy way to do it
    Huh so, where can I fined the hard way? And ones more, thanx everyone trying to help me.
  13. Member Soopafresh's Avatar
    Download the 3 day demo of Neo Scene.
    Convert the M2TS files to Cineform AVI.
    Then open the AVIs in VirtualDub or Xvid4PSP to create your XVid AVIs
    It works, but 3 days demo sucks a bit, why are those codecs massed up when trying to open M2ts in Xvid4pSp, is there other solution.
    Is it posible to save in xvid with Adobe premier?
    Sweet the solution is here , I copy .MTS file directly from camera HDD and Xvid4PSP opened it no problemo sweet!!!
  17. I'm a MEGA Super Moderator Baldrick's Avatar
    How did you copy/transfer it before? Isn't it the same method or does it add something to the video file?
    (I have no sony camcorder as you can guess.... )
  18. Member
    With Sony Handycam Utility and it changes extension from .MTS to .m2ts...
  19. Member Heliooos's Avatar
    yes,
    this also causes me much headache. My friend gave me some m2ts video from his Sony camcorder and I also have this problem. I tried different methods but without success:
    1) rename extension to mts and use _multi_demux_mts_Xvid.bat from here:
    http://forum.videohelp.com/topic347139-30.html#1910831
    - operation stops after short time with no video converted
    2) directshowsource via Avidemux or Virtualdub and Avisynth. Both load the video but there is problems with saving as normal avi (resized to 720x400 or something similar).Virtualdub worked 24 hours (for 1.5 hours video) and produced damaged video (with approx. same size as original) with wrong FPS and MPC also reported some problem with chunks. Avidemux worked about 30 minutes, the video was smaller, but with no sound.
    3) Mediacoder also failed
    so I am going to try to get the mts directly from camera and try again.
    i have converted HD H-264 (MKV) download files from the net to standard def Xvid format if thats what your after.
    i used Super 2009, its about the only tool i found that would import these to output to SD Xvid, as my regular video encoder (TMPGEnc xpress) wont.
    http://www.erightsoft.com/SUPER.html
    i will leave it up to you to find the download links, but these people make this tool freely available, yet make us work like shit to find the right download sources, and its a joke.
  21. Always Watching guns1inger's Avatar
    Never quite understood why everyone gets so out shape over the SUPER download links. Yes, it isn't the most intuitive site to download from (although it's not that hard), but there is a direct link in the Tools section that bypasses the need to get it from erightsoft's poorly designed website anyway.
    Many thanks to Baldrick for hosting so much of the software we need every day.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  22. Member Heliooos's Avatar
    I tried latest SUPER, but the video is strange. When I use mencoder and 720x576 3000 kbps XVID with MP3 sound - it takes many hours, the file is not much smaller then original.
    Here are detail for the m2ts file obtained by Mediacoder:
    Complete name                    : C:\konverze\20090505014629.m2ts
    Format                           : BDAV
    Format/Info                      : BluRay Video
    File size                        : 2.26 GiB
    Duration                         : 1h 5mn
    Overall bit rate                 : 4 921 Kbps
    Maximum Overall bit rate         : 18.0 Mbps
    Video
    Menu ID                          : 1 (0x1)
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : Main@L4.0
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 2 frames
    Duration                         : 1h 5mn
    Bit rate                         : 4 269 Kbps
    Width                            : 1 440 pixels
    Height                           : 1 080 pixels
    Display aspect ratio             : 16/9
    Frame rate                       : 25.000 fps
    Resolution                       : 24 bits
    Colorimetry                      : 4:2:0
    Scan type                        : Interlaced
    Scan order                       : Top Field First
    Audio
    Menu ID                          : 1 (0x1)
    Format                           : AC-3
    Format/Info                      : Audio Coding 3
    Duration                         : 1h 5mn
    Bit rate mode                    : Constant
    Bit rate                         : 448 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Rear: L R, LFE
    Sampling rate                    : 48.0 KHz
    Video delay                      : -80ms
    The avi file produced by SUPER (with settings above) is probably not correct, because I always get this message:
    For comparison here is info for one of my MTS files from our Canon HF-10 which I can convert without problem with that batch script (I use this file for testing):
    General
    Complete name                    : C:\mts_2_xvid\00288.MTS
    Format                           : BDAV
    File size                        : 8.39 MiB
    Duration                         : 10s 979ms
    Overall bit rate                 : 6 411 Kbps
    Maximum Overall bit rate         : 13.7 Mbps
    Video
    Menu ID                          : 1 (0x1)
    Format                           : AVC
    Format profile                   : High@L4.0
    Duration                         : 10s 960ms
    Bit rate                         : 5 892 Kbps
    Colorimetry                      : 4:2:0
    Audio
    Menu ID                          : 1 (0x1)
    Format                           : AC-3
    Bit rate                         : 256 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : L R
    Video delay                      : -80ms
    I wil try to use ffmpeg.
  23. Member Heliooos's Avatar
    so finally,
    problem solved. I used AVANTI (version 0.3.7) with FFmpeg SVN-r19163 and converted to XVID Avi 720x576 with 128 Kbps MP3 sound (44 KHz) - checked "Deinterlace", Frame size 720x576, Frame rate "Source", Colorspc. "Source", Aspect ratio "Source". And produced avi file has finally correct sound and fps.
  24. Member
    Originally Posted by Heliooos
    so finally,
    hi m8, i use Super 2009 a lot for converting high def H264 mkv files to SD Xvid as i find it does it very well with excellent quality, and i only output to Xvid because my dvd players wont play H264 and nor will my current SD noontek hdd media players.
    with my mpeg2 to Xvid i use tmpgenc at the moment and use the deinterlace option but i output to a target quantizer of 3.0 not a fixed bitrate, and i also output to 44100 @ 128 audio for Xvid, where my mpeg2 files are 48000 @ 224
    cheers
  1. M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
    By messi magician in forum Authoring (Blu-ray)
    Last Post: 15th Jan 2012, 18:25
  2. mux m2ts to m2ts with AC3 audio without reencoding the video
    By BirdDaddie in forum Video Conversion
    Last Post: 22nd Aug 2010, 21:19
  3. software to batch convert m2ts format avchd to mts avchd?
    By masterpug in forum Video Conversion
    Last Post: 14th Aug 2010, 01:06
  4. Replies: 7
    Last Post: 27th Feb 2010, 21:54
  5. Editing AVCHD (.m2ts)
    By 4real1970 in forum Newbie / General discussions
    Last Post: 25th Sep 2007, 13:50
