Hi
I was trying to extract VTS files form DVD using Isobuster.The first VTS file can not be extract. The software shows a message that tells us about corrupted file...Is any other chance to extract the VTS files? Thanks
is it a commercial dvd? might be part of the protection scheme. try running it through dvdfabdecrypter first.
No is a family DVD. Long time not using that.
If it is home made DVD, than use Explorer, OPEN DVD and copy/drag VIDEO_TS folder to a new place on your hard drive.
Yeah I did it, but the first VTS and the third one, are not going to be copied to hard drive (corrupted file says) How to fix that?Originally Posted by tinker
isobuster and cdroller are about the only decent programs to try to extract data from bad discs. you can try washing the disc with warm water and soap, and using a different dvd drive to check if yours isn't reading very well but there's not much hope. if the dye layer has deteriorated then it's just gone.
Yea, I tried that, cleaning the DVD. But the message that I got, was "corrupted file". I am talking about VTS file, during copy proccess from DVd to HD.Originally Posted by minidv2dvd
you can try to copy off just the vobs and make a new dvd if you can get them all off of the dvd.
there are lots of files starting with vts on a dvd.
Trying to extract VOB file with Isobuster, nothing happens?
By dai3504 in forum DVD RippingReplies: 2Last Post: 8th May 2011, 10:42 -
Burning to DVD with VTS files
By cameraz in forum Newbie / General discussionsReplies: 5Last Post: 18th Nov 2009, 21:18 -
Creating DVD-s from VTS folder files
By 1234567 in forum Authoring (DVD)Replies: 6Last Post: 16th Feb 2009, 12:40 -
vts files to burn a DVD
By pcalabria in forum DVD RippingReplies: 4Last Post: 15th Feb 2009, 02:50 -
Bruning a DVD from VOB / VTS files
By davidvignola in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2007, 06:53
