(why do I find it so hard to type Samsung? Ah well...)
At work, I use a Samsung DVD R155 to record programmes off TV for playback in lessons (I work in an FE college) on computers, however, a couple of minutes into a chapter the playback stops. This happens no matter what software I use to play it; we have Windows Media Player (the most commonly used one), RealPlayer and CyberLink PowerDVD on the computers, and I have also tried it in Media Player Classic. Each time the same problem occurs.
Does anybody know why this is, or any way I can solve this problem?
Thanks,
I'd question the recording. If the same problem occurs with multiple players, then there is likely an issue with your recordings.
Google is your Friend
Yes, I'd already figured that it was the recording. What I am asking is whether it's fixable (for future recordings) or workaroundable (for existing recordings, for instance ripping and reburning).
Does it playback properly in the recorder? It's possible the data isn't even on the disc, in which case it can't be fixed.
What brand of blank disc was used? See www.nomorecoasters.com
You might have used a cheap disc, and the disc is bad.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Problem with Samsung DVD-R155
By eatonsboy in forum DVD & Blu-ray RecordersReplies: 1Last Post: 13th Feb 2010, 13:01 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Help - Samsung R155 multi region unlock code needed
By pixie in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Aug 2008, 10:33 -
[SOLVED] Playing recorded DVDs on the computer (Samsung DVD-SH853)
By ToniVC in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Nov 2007, 13:59 -
region hack for samsung dvd recorder dvd-r155
By monks19 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 23rd Jun 2007, 18:05
