Hey there guys. I've had a Pioneer Dual Layer 110D for a few years now. It's always been fine. But I recently got a new PC and all of a sudden I'm having issues with some of my backup software. I'm getting lots of retries, failed attempts, and a couple of game backups which worked flawlessly in the past are burning with issues. Perhaps I have my settings on this software wrong on the new tower (and I'd rather not mention them in case they shouldn't be brought up) but I'm thinking hardware must be the problem because all other variables are the same. No, media is not the problem. I'm all over that. Also, the drive is in an external enclosure and isn't seen by DISCinfo.
If you think I should just be getting a new burner now, please recommend a DL internal SATA drive that I can get which can be flashed to be region free, is of the best quality, and will have no problem burning discs through any backup software.
Thanks to you all for any help!!
Closed Thread
Results 1 to 30 of 35
tinpanalley, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
If you are absolutely sure the media isn't the problem, then maybe the burner is failing. I would try cleaning the laser lens before I trash it. But if you are looking for SATA burners, Pioneer is still a good choice. Samsung also.
And welcome to our forums.
Thank you very very much. I will be more specific with my posts.
Are you able to answer which Pioneer drive might be flashable for multi-region like the 110 was? Or is that question off limits? Don't want to get anyone in trouble.
No problem with the question, though I don't know the answer.
Someone here probably does, or check out CD Freaks as they have a lot of information on DVD drives: http://club.cdfreaks.com/
The interaction between host computer, backup software and burner can sometimes be tricky to troubleshoot. In your case, if your Pio 110 was heavily used for backups, it may just be coincidence that it has finally worn out at the same time you plugged it into a new PC. One random issue with the Pio 110 is simply that its an "even number" model: until recently, Pioneer had an peculiar pattern where the "even number" burners were way twitchy and the "odd number" burners were were more stable, compatible and bug-free (i.e. the 107, 109 and 111 were a lot better than the 108, 110 and 112). You'd do well to follow redwudz suggestion to search the CDfreaks forum, they explore burner issues in great depth (although a number of burner experts here will likely chime in over the next few days with good advice). The combination of persnickety DVR-110, external USB case and your new PC motherboard might simply be incompatible: if your new PC can accept internal EIDE drives, you could remove your 110 from its USB enclosure and see if it works better installed directly in the PC case. If your old PC was running XP, and your new one is running Vista, the old burner/USB enclosure may not be completely Vista-approved. Etc, etc.
BTW, the "odd/even" pattern seemed to stop after some weird problems surfaced on the Pioneer 112, causing a recall. Newer Pioneers with model numbers above 112 have so far proved more consistent and are quite good overall. Considering how cheap a burner is nowadays, it can't hurt to try a new one if your old one starts flaking.
I had no idea. I was always under the impression that the 110D was one of the best internal DVD burners you could buy.Originally Posted by orsetto
It only has SATA and has left me in a bind with all my EIDE drives. Outside of replacing the power supply, I'm stuck with what I've got for connectors and regretting more and more every day not having built my own system which I always swore I would do. Regardless, without getting off topic, that's the reason for the enclosure. It was my only choice. But given how much easier a SATA internal would make things, I'm thinking I'll just find out what the best drive is that has RPC1 firmware available, burns as flawlessly as possible, and covers the most types of media.Originally Posted by orsetto
Thanks for your help everyone. I'd still appreciate any further suggestions.
I cannot fully agree. 107 was a non DL animal, but good. 108 and 109 were not thatgood, but 110 and 111 kicked and still kickin here. 112 was half / half and 115 and 116 straight to the top again.Originally Posted by orsetto
Because you have got a new pc with a new mobo, I think these issues are more controller related.
What is the atapi/ide controller on the new mobo and how is it set up?*** Now that you have read me, do some other things. ***
Hey, thanks for the reply. How do I find out the answer to those questions?Originally Posted by [_chef_
post your motherboard brand/model. if your mobo has a nvidia sata chipset controller you'll need to download the latest drivers from the nvidia website in order for a SATA dvd burner to work correctly. if your mobo has intel ICH 7/8/9/10 sata chipset controller a SATA dvd burner will work fine. the via chipset controllers will not work with SATA dvd burners. you'd have to use a PCI SATA controller card that uses the SILICON IMAGE 3114, 3512 or 3124 chipset.Originally Posted by tinpanalley
earlier versions of JMICRON sata controller chipsets also don't work with SATA dvd burners. but i have read that the latest JMICRON chipsets may work, it depends on the mobo model and make. also you'll have to disable RAID in the mobo bios and set SATA to IDE in order for a SATA DVD burner to work correctly.
my suggestion if you have the right mobo sata controllers is to buy a PIONEER 216 SATA dvd burner.
Computer Brand Name: Gateway ET1161-03 (it's an emachines)
Motherboard Model: ECS MCP61PM-GM
Motherboard Chipset: nVidia nForce 6100-430
And this is the drive that's in there now. It's a SATA drive.
Drive Model: INULO W5IVS5UBGDA3
I just wanna be able to flash a new SATA drive with RPC1 firmware. So, if you give me some opinions about the Pioneer 216 or the Optiarc AD-7200S, that would be great.
For those of you that have replied, here is a log of the two errors I always get if someone can still help me figure out where my problem is:
Reason: The semaphore timeout period has expired.
and
Reason: Power On, Reset, or Bus Device Reset Occurred
at about 15:58:00
I 15:55:24 ImgBurn Version 2.4.2.0 started!
I 15:55:24 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
I 15:55:24 Total Physical Memory: 3,013,036 KB - Available: 2,487,160 KB
I 15:55:24 Initialising SPTI...
I 15:55:24 Searching for SCSI / ATAPI devices...
I 15:55:34 Found 1 DVD±RW, 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
I 15:56:07 Operation Started!
I 15:56:07 Source File: D:\Games\XBOX\TY_The_Tasmanian_Tiger_NTSC_XBOX-BCG\tyttt-bcg\TY The Tasmanian Tiger NTSC XBOX.iso
I 15:56:07 Source File Sectors: 756,736 (MODE1/2048)
I 15:56:07 Source File Size: 1,549,795,328 bytes
I 15:56:07 Source File File System(s): ISO9660
I 15:56:07 Destination Device: [0:0:0] PIONEER DVD-RW DVR-110D 1.37 (K
(USB)
I 15:56:07 Destination Media Type: DVD-R (Disc ID: MCC 02RG20) (Speeds: 4x, 6x, 8x)
I 15:56:07 Destination Media Sectors: 2,297,888
I 15:56:07 Write Mode: DVD
I 15:56:07 Write Type: DAO
I 15:56:07 Write Speed: 2.4x
I 15:56:07 Link Size: Auto
I 15:56:08 Test Mode: No
I 15:56:08 OPC: No
I 15:56:08 BURN-Proof: Enabled
I 15:56:08 Filling Buffer... (40 MB)
I 15:56:09 Writing LeadIn...
I 15:56:48 Writing Session 1 of 1... (1 Track, LBA: 0 - 756735)
I 15:56:48 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 756735)
W 15:58:03 Failed to Write Sectors 202176 - 202207 - Reason: The semaphore timeout period has expired.
W 15:58:03 Retrying (1 of 20)...
W 15:58:04 Retry Failed - Reason: Power On, Reset, or Bus Device Reset Occurred
W 15:58:04 Retrying (2 of 20)...
I 15:58:04 Writing Sectors...
I 16:01:31 Synchronising Cache...
I 16:01:55 Exporting Graph Data...
I 16:01:55 Graph Data File: C:\Documents and Settings\Desktop\Application Data\ImgBurn\Graph Data Files\PIONEER_DVD-RW_DVR-110D_1.37_SUNDAY-JANUARY-25-2009_3-56_PM_MCC_02RG20_2.4x.ibg
I 16:01:55 Export Successfully Completed!
I 16:01:55 Operation Successfully Completed! - Duration: 00:05:48
I 16:01:55 Average Write Rate: 5,347 KB/s (3.9x) - Maximum Write Rate: 5,671 KB/s (4.1x)
I 16:01:55 Cycling Tray before Verify...
W 16:02:05 Waiting for device to become ready...
I 16:31:54 Device Ready!
I 16:31:55 Operation Started!
I 16:31:55 Source Device: [0:0:0] PIONEER DVD-RW DVR-110D 1.37 (K
(USB)
I 16:31:55 Source Media Type: DVD-R (Book Type: DVD-R) (Disc ID: MCC 02RG20) (Speeds: 4x, 6x, 8x)
I 16:31:55 Image File: D:\ [GAME I WAS BURNING HERE] .iso
I 16:31:55 Image File Sectors: 756,736 (MODE1/2048)
I 16:31:55 Image File Size: 1,549,795,328 bytes
I 16:31:55 Image File File System(s): ISO9660
I 16:31:55 Read Speed (Data/Audio): MAX / MAX
I 16:31:55 Verifying Session 1 of 1... (1 Track, LBA: 0 - 756735)
I 16:31:55 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 756735)
I 16:34:45 Exporting Graph Data...
I 16:34:46 Graph Data File: C:\Documents and Settings\Desktop\Application Data\ImgBurn\Graph Data Files\PIONEER_DVD-RW_DVR-110D_1.37_SUNDAY-JANUARY-25-2009_3-56_PM_MCC_02RG20_2.4x.ibg
I 16:34:46 Export Successfully Completed!
I 16:34:46 Operation Successfully Completed! - Duration: 00:02:50
I 16:34:46 Average Verify Rate: 8,902 KB/s (6.4x) - Maximum Verify Rate: 11,548 KB/s (8.3x)
you have the a nvidia chipset mobo. go to the nvidia website and download the latest sata controller drivers. don't use the mobo website, it has to be the nvidia website.
are you using a 80 wire ide cable for you PIONEER 110 drive? ide cables can fail so buy a new 80 wire ide cable and try that route first. if that doesn't work then your PIONEER 110 drive could just be dying a slow death. buy a new dvd burner which is so cheap these days. also try using VERBATIM DVD+R media. some VERBATIM DVD-R could be crappy as they had a batch months ago that had problems.
as for flashing a sata drive with a RPC1 firmware it's not difficult. you can just use MEDIA CODE SPEED EDIT to make it region free. do a google search on MEDIA CODE SPEED EDIT or go to the TOOLS section here to find it.
Here are some links at Newegg .... in case you decide to get a new burner .... I do like Lite-On ... I have a few of them and none of them have been duds ... I have been buying them over last few years.
Actually ... I have not had a DVD Burner die on me yet ... I do burn DVDs quite often but 3 PCs in my home ... that I use ... has two burners in them.
On one PC ... one of the two burners sits on top thru a USB connection. Oh ... I forgot there is a USB Pioneer 109 sitting next to the other PC. Total burners in use ... 8 of them connected and being used.
On the PC in my garage ... two inside my machine and another USB burner [Plextor] sitting on the table ... I also have a few Panasonic DVD Burners ... 3 of them. I guess because I have so many of them ... the wear and tear is spread out among all of them.
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner - OEM
http://www.newegg.com/Product/Produc...82E16827106263
$21.99
Free Shipping
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 2MB Cache E-IDE/ATAPI 20X DVD±R DVD Burner with LightScribe - OEM
http://www.newegg.com/Product/Produc...82E16827106229
$24.99
Free Shipping
Pioneer 20X DVD±R DVD Burner Beige IDE Model DVR-116D - OEM
Your Price
25.99 ... no free shipping
http://www.newegg.com/Product/Produc...82E16827129024
Here is a good price for a USB external enclosure
Powemax Aluminum 5.25" USB 2.0 External Drive Enclsoure, Model EN525SL-U, Free Ground Shipping
$21.99
http://www.meritline.com/aluminum-5-...enclsoure.html
PRODUCT INFO
The all aluminum 5.25" USB 2.0 external drive enclsoure is compatible with notebooks and desktop pcs, providing a past and easy way to add more storage and versatitity to your computer.
Features & Specifications:
Aluminum enclsoure
External enclosure for 3.5" inch IDE drives (hard drives)
External enclosure for 5.25 inch IDE CD-ROM, CD Writers, DVD ROM, DVD Writers
Compatitble with notebook and desktop pcs
USB 2.0 interface (backwards compatible with USB 1.1)
Supports up to 480Mbps, 40x paster than USB 1.1
40mm fan for heat extraction
LED Status display for power and activity
Power ON/OFF switch
Audio left/right output
Plug & Play installation
Supports Windows 98,2000,ME,XP,Mac OS 8.6 or above
Packaging:
One aluminum 5.25 inch USB enclsoure
One power adapter
CD with drivers
USB 2.0 cable
tinpanalley,
When you're burning something, it's actually accomplished through a series of steps that require a continuing conversation between the burning software and the drive.
In the burn log you posted:means the drive stopped talking to (communicating with) the software.The semaphore timeout period has expiredmeans the drive reset to correct the error condition. Once that happens, the burning can't continue and that particular disk becomes a coaster.Power On, Reset, or Bus Device Reset Occurred
You should check all the connections to the drive inside the external enclosure, and the enclosure's usb cable's connections on both ends. If that doesn't fix the problem, try a different usb cable. Also try connecting any other external device to that usb connector on the computer to see if that's the problem.
Still doesn't work?
When the drive in question worked before, was it internal, in the same external enclosure as it is now, or in a different enclosure?
If the answer is either "internal" or "in a different enclosure", the prime suspect is you're currently using a faulty enclosure.
If the answer is "in the same external enclosure", it's more difficult to diagnose. It could be the drive failing, the enclosure failing, or the usb on the new computer has a problem.
On a separate note, having absolutely nothing to do with your current problem, the burn log shows you asked for 2.4x burning speed, but the drive only has 4x, 6x, and 8x write strategies for that media, so it went with the 4x write strategy. It isn't going to hurt anything to ask for 2.4x, but you're never going to get it, so there isn't much point in asking for it.
Hey all. Thank you for the continued help. I've replaced the EIDE ribbon cable in the enclosure. I'm guessing the only way to test it is by burning another disc, huh? If there's some other test I can do please let me know. I've got enough coasters.
VegasBud, thanks for all the help and suggestions. The drive used to be inside my tower hooked up via Molex power and IDE cable. Unfortunately, not an option in the new tower. I doubt that it's the enclosure because I trust the products sold here at B&H in New York and having had enclosures before, this is a substantial product. But, it very well could be and I'll find out by process of elimination.
Consequently, someone over at CDfreaks told me that I should run chkdsk /f /r /x on the harddrive that contains the data because that error means it's having trouble reading. Well chkdsk found no problems so that was fruitless.
Anyway, I guess I'll post back when I've tried another burn.
Another burn, same problems.
Also, DVD Decrypter doesn't even seem to want to see the drive at all. Only lists my internal drive.
I 19:54:08 ImgBurn Version 2.4.2.0 started!
I 19:54:08 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
I 19:54:08 Total Physical Memory: 3,013,036 KB - Available: 2,424,532 KB
I 19:54:08 Initialising SPTI...
I 19:54:08 Searching for SCSI / ATAPI devices...
I 19:54:08 Found 1 DVD±RW, 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
W 19:55:08 I/O Interface has been changed!
I 19:55:08 Shutting down SPTI...
I 19:55:08 Initialising ASPI...
I 19:55:08 WNASPI32.DLL - Adaptec's ASPI Layer - ASPI for Win32 (95/NT) DLL - Version 4.6.0.1021
I 19:55:08 Searching for SCSI / ATAPI devices...
I 19:55:08 Found 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
W 19:55:27 I/O Interface has been changed!
I 19:55:27 Shutting down ASPI...
I 19:55:27 Initialising SPTI...
I 19:55:27 Searching for SCSI / ATAPI devices...
I 19:55:27 Found 1 DVD±RW, 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
I 19:55:33 Operation Started!
I 19:55:34 Source File: D: [ GAME ].iso
I 19:55:34 Source File Sectors: 756,736 (MODE1/2048)
I 19:55:34 Source File Size: 1,549,795,328 bytes
I 19:55:34 Source File File System(s): ISO9660
I 19:55:34 Destination Device: [0:0:0] PIONEER DVD-RW DVR-110D 1.37 (K
(USB)
I 19:55:34 Destination Media Type: DVD-R (Disc ID: MCC 02RG20) (Speeds: 4x, 6x, 8x)
I 19:55:34 Destination Media Sectors: 2,297,888
I 19:55:34 Write Mode: DVD
I 19:55:34 Write Type: DAO
I 19:55:34 Write Speed: 4x
I 19:55:34 Link Size: Auto
I 19:55:34 Test Mode: No
I 19:55:34 OPC: No
I 19:55:34 BURN-Proof: Enabled
I 19:55:34 Filling Buffer... (40 MB)
I 19:55:35 Writing LeadIn...
I 19:56:14 Writing Session 1 of 1... (1 Track, LBA: 0 - 756735)
I 19:56:14 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 756735)
W 19:59:22 Failed to Write Sectors 504448 - 504479 - Reason: The semaphore timeout period has expired.
W 19:59:22 Retrying (1 of 20)...
W 19:59:23 Retry Failed - Reason: Power On, Reset, or Bus Device Reset Occurred
W 19:59:23 Retrying (2 of 20)...
I 19:59:23 Writing Sectors...
I 20:00:57 Synchronising Cache...
I 20:01:21 Exporting Graph Data...
I 20:01:21 Graph Data File: C:\Documents and Settings\Desktop\Application Data\ImgBurn\Graph Data Files\PIONEER_DVD-RW_DVR-110D_1.37_MONDAY-JANUARY-26-2009_7-55_PM_MCC_02RG20_4x.ibg
I 20:01:21 Export Successfully Completed!
I 20:01:21 Operation Successfully Completed! - Duration: 00:05:47
I 20:01:21 Average Write Rate: 5,347 KB/s (3.9x) - Maximum Write Rate: 5,566 KB/s (4.0x)
I 20:01:21 Cycling Tray before Verify...
I 20:01:50 Device Ready!
I 20:01:50 Operation Started!
I 20:01:50 Source Device: [0:0:0] PIONEER DVD-RW DVR-110D 1.37 (K
(USB)
I 20:01:50 Source Media Type: DVD-R (Book Type: DVD-R) (Disc ID: MCC 02RG20) (Speeds: 4x, 6x, 8x)
I 20:01:50 Image File: D: [ GAME ] .iso
I 20:01:50 Image File Sectors: 756,736 (MODE1/2048)
I 20:01:50 Image File Size: 1,549,795,328 bytes
I 20:01:51 Image File File System(s): ISO9660
I 20:01:51 Read Speed (Data/Audio): MAX / MAX
I 20:01:51 Verifying Session 1 of 1... (1 Track, LBA: 0 - 756735)
I 20:01:51 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 756735)
I 20:04:41 Exporting Graph Data...
I 20:04:41 Graph Data File: C:\Documents and Settings\Desktop\Application Data\ImgBurn\Graph Data Files\PIONEER_DVD-RW_DVR-110D_1.37_MONDAY-JANUARY-26-2009_7-55_PM_MCC_02RG20_4x.ibg
I 20:04:41 Export Successfully Completed!
I 20:04:41 Operation Successfully Completed! - Duration: 00:02:50
I 20:04:41 Average Verify Rate: 8,902 KB/s (6.4x) - Maximum Verify Rate: 11,526 KB/s (8.3x)
tinpanalley,
The bad news is you have the same problem...the worse news is now the burn log is showing that when it was setting up, ImgBurn tried to use the default SPTI, aborted, tried ASPI as an alternate, aborted that, went back to SPTI, and finally managed to get to the point where it failed the same way as before.
I still suspect the enclosure, but other things to check would include:
If the enclosure is connected through a usb hub, try eliminating the hub.
Are there any warnings in Device Manager for the usb controller or the drive-in-the-enclosure?
The burn logs are consistently showing a break down in communication specifically between the software and the burner. I wouldn't waste time on anything (like running chkdsk) that doesn't involve the connection chain between the burner (which is very likely still fine) and the software (which is not the problem).
If anything else occurs to me, I'll certainly let you know.
Hey,
The SPTI, ASPI thing was me messing around with settings. I'm thinking that for the benefit of SATA and for the benefit of not having an enclosure dangling off my computer, and with prices being so low on burners, I'll just cave and get either the Optiarc AD-7200S or the Pioneer 216. I wanted to solve this cause I'm a tech-geek and wanted to beat it, but it's becoming more trouble than the solution which is so cheap.
What do you think?
Can you test the burner internally?
I bet it works, but usb sucks.*** Now that you have read me, do some other things. ***
Just so you guys can take a look... this is what happens when I try to burn with the internal SATA drive with IMGburn.
Same image file as before.
What the hell??
I 21:17:46 ImgBurn Version 2.4.2.0 started!
I 21:17:46 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
I 21:17:46 Total Physical Memory: 3,013,036 KB - Available: 2,296,440 KB
I 21:17:46 Initialising SPTI...
I 21:17:46 Searching for SCSI / ATAPI devices...
I 21:18:07 Found 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
I 21:20:19 Operation Started!
I 21:20:19 Source File: D:\[GAME].iso
I 21:20:19 Source File Sectors: 756,736 (MODE1/2048)
I 21:20:19 Source File Size: 1,549,795,328 bytes
I 21:20:19 Source File File System(s): ISO9660
I 21:20:19 Destination Device: [2:1:0] HL-DT-ST DVDRAM GH15F EG00 (H
(ATA)
I 21:20:20 Destination Media Type: DVD-R (Disc ID: MCC 02RG20) (Speeds: 4x, 8x)
I 21:20:20 Destination Media Sectors: 2,298,496
I 21:20:20 Write Mode: DVD
I 21:20:20 Write Type: DAO
I 21:20:20 Write Speed: 4x
I 21:20:20 Link Size: Auto
I 21:20:20 Test Mode: No
I 21:20:20 OPC: No
I 21:20:20 BURN-Proof: Enabled
I 21:20:20 Filling Buffer... (40 MB)
I 21:20:21 Writing LeadIn...
W 21:20:25 Failed to Write Sectors 0 - 31 - Reason: Unknown (0x67, 0x00)
W 21:20:25 Retrying (1 of 20)...
W 21:20:25 Retry Failed - Reason: CD Control Error
W 21:20:25 Retrying (2 of 20)...
W 21:20:25 Retry Failed - Reason: No Additional Sense Information
W 21:20:25 Retrying (3 of 20)...
W 21:20:25 Retrying (4 of 20)...
W 21:20:25 Retrying (5 of 20)...
W 21:20:25 Retrying (6 of 20)...
W 21:20:25 Retrying (7 of 20)...
W 21:20:25 Retrying (8 of 20)...
W 21:20:25 Retrying (9 of 20)...
W 21:20:25 Retrying (10 of 20)...
W 21:20:25 Retrying (11 of 20)...
W 21:20:25 Retrying (12 of 20)...
W 21:20:25 Retrying (13 of 20)...
W 21:20:25 Retrying (14 of 20)...
W 21:20:25 Retrying (15 of 20)...
W 21:20:25 Retrying (16 of 20)...
W 21:20:25 Retrying (17 of 20)...
W 21:20:25 Retrying (18 of 20)...
W 21:20:25 Retrying (19 of 20)...
W 21:20:25 Retrying (20 of 20)...
E 21:20:31 Failed to Write Sectors 0 - 31 - Reason: Unknown (0x67, 0x00)
I 21:20:31 Synchronising Cache...
W 21:20:32 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Unknown (0x67, 0x00)
W 21:20:33 Synchronise Cache Failed! - Reason: Unknown (0x67, 0x00)
W 21:20:33 Retrying (1 of 3)...
W 21:20:34 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Unknown (0xB0, 0x68)
W 21:20:35 Retry Failed - Reason: Unknown (0xB0, 0x68)
W 21:20:35 Retrying (2 of 3)...
W 21:20:46 User opted to skip the 'Close Track/Session/Disc' functions.
E 21:20:46 Failed to Write Image!
E 21:20:46 Operation Failed! - Duration: 00:00:26
I 21:20:46 Average Write Rate: N/A - Maximum Write Rate: N/A
tinpanalley,
Wow...that's really impressive...in a horrendous sort of way.
I guess we should start with what the reported errors were:is a configuration error.Reason: Unknown (0x67, 0x00)is actually supposed to be a media error, but with MCC 02RG20 media, that's really not likely.Reason: CD Control Errormeans either the drive didn't report what the error is, or (more likely) the error code the drive reported was lost before it got back to the software, which would be back to some kind of communication error.Reason: No Additional Sense Information
With the information available, I'm starting to think there's some unidentified problem in a controller or its' driver. If you go into Device Manager, are there any problems being reported...of any kind? If so, what are they?
The only other thing I can think of that you could try would be to generate a debug burn log, where I can step through the detailed conversation between the software and the drive, hopefully to see more exactly what is going on. I've got to warn you that since I don't have a lot a free time, it could take a few days to report back to you. If you're willing to give it a shot, so am I. If you're interested, follow the steps below.
1) Start ImgBurn
1a) Use "Test Mode" to do a simulated burn. There's no reason to waste any more media.
2) Press the F6 key to turn on debug mode
3) Proceed as normal
4) Post the debug burn log
Hey Vegas,
Thanks again...
1. I tried what you mentioned, but I couldn't seem to get Test Mode to work. Do I have to have a disc in the drive?
2. I bought this last night because I'm starting to get sick of trying to force EIDE to work when I have an empty drive bay that my computer will probably work with. Although now, even the one in my tower isn't working through IMGburn and Decrypter. I think this problem may have occurred after I upgraded my mobo's SATA controllers but the drive never burned through those programs to be honest.
Pioneer 20X DVD±R DVD Burner SATA Model DVR-216DBK
Thanks again!
tinpanalley,
Yes, you need to have a blank disk in the drive for test mode to work. Make sure it's a -R disk, and nothing will be written to the disk, so you can use the disk in the future. If it's a +R disk, even though it's in test mode, it still results in a full burn...and another coaster.
I was actually stopping by to let you know that by puttinginto google, there were 90 some hits for people having assorted problems with nvidia drivers for nvidia sata controllers. Some of those reported problems sounded similiar to your last burn log. LightningUK! says the next version of ImgBurn has a workaround for nvidia driver issues, but that version hasn't been released yet. You might want to take a look at some of the threads there to see how other people are dealing with the (maybe related) problem.Code:site:imgburn.com nvidia nforce
Here is the log for IMGBurn using the internal drive...
The log for the Pioneer drive follows in the next post.
I 00:40:08 ImgBurn Version 2.4.2.0 started!
I 00:40:08 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 3)
I 00:40:08 Total Physical Memory: 3,013,036 KB - Available: 2,362,404 KB
I 00:40:08 Initialising SPTI...
I 00:40:08 Searching for SCSI / ATAPI devices...
I 00:40:08 Found 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM!
W 00:42:12 Program 'Debug Mode' has been Enabled!
I 00:42:42 Operation Started!
I 00:42:42 Source File: D:\game.iso
I 00:42:42 Source File Sectors: 756,736 (MODE1/2048)
I 00:42:42 Source File Size: 1,549,795,328 bytes
I 00:42:42 Source File File System(s): ISO9660
I 00:42:42 Destination Device: [2:1:0] HL-DT-ST DVDRAM GH15F EG00 (H
(ATA)
I 00:42:42 Destination Media Type: DVD-R (Disc ID: MCC 02RG20) (Speeds: 4x, 8x)
I 00:42:42 Destination Media Sectors: 2,297,888
I 00:42:42 Write Mode: DVD
I 00:42:42 Write Type: DAO
I 00:42:42 Write Speed: 4x
I 00:42:42 Link Size: Auto
I 00:42:42 Test Mode: Yes
I 00:42:42 OPC: No
I 00:42:42 BURN-Proof: Enabled
D 00:42:43 Logical Unit Most Desirable Link Size: 16
D 00:42:43 Device Buffer Size: 1,114,112 bytes.
D 00:42:43 Device Buffer Available: 1,114,112 bytes.
I 00:42:43 Filling Buffer... (40 MB)
I 00:42:44 Writing LeadIn...
W 00:42:44 Failed to Write Sectors 0 - 31 - Reason: No Additional Sense Information
W 00:42:44 Retrying (1 of 20)...
W 00:42:44 Retry Failed - Reason: No Additional Sense Information
W 00:42:44 Retrying (2 of 20)...
W 00:42:44 Retrying (3 of 20)...
W 00:42:44 Retrying (4 of 20)...
W 00:42:44 Retrying (5 of 20)...
W 00:42:44 Retrying (6 of 20)...
W 00:42:44 Retrying (7 of 20)...
W 00:42:44 Retrying (8 of 20)...
W 00:42:44 Retrying (9 of 20)...
W 00:42:44 Retrying (10 of 20)...
W 00:42:44 Retrying (11 of 20)...
W 00:42:44 Retrying (12 of 20)...
W 00:42:44 Retrying (13 of 20)...
W 00:42:44 Retrying (14 of 20)...
W 00:42:44 Retrying (15 of 20)...
W 00:42:44 Retrying (16 of 20)...
W 00:42:44 Retrying (17 of 20)...
W 00:42:44 Retrying (18 of 20)...
W 00:42:44 Retrying (19 of 20)...
W 00:42:44 Retrying (20 of 20)...
W 00:42:46 Retrying (21)...
W 00:42:46 Retry Failed - Reason: CD Control Error
W 00:42:46 Retrying (22)...
W 00:42:47 Retrying (23)...
W 00:42:47 Retry Failed - Reason: CD Control Error
W 00:42:47 Retrying (24)...
W 00:42:48 Retrying (25)...
W 00:42:48 Retry Failed - Reason: No Additional Sense Information
E 00:42:51 Failed to Write Sectors 0 - 31 - Reason: No Additional Sense Information
I 00:42:51 Synchronising Cache...
D 00:42:52 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Unknown (0x67, 0x00)
W 00:42:52 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Unknown (0x67, 0x00)
W 00:42:53 Synchronise Cache Failed! - Reason: Unknown (0x67, 0x00)
W 00:42:53 Retrying (1 of 3)...
I 00:42:59 Cycling Tray after Test Write...
E 00:42:59 Failed to Write Image!
E 00:42:59 Operation Failed! - Duration: 00:00:16
I 00:42:59 Average Write Rate: N/A - Maximum Write Rate: N/A
Pioneer 110 test burn log...
W 00:48:01 Program 'Debug Mode' has been Enabled!
I 00:48:03 Operation Started!
I 00:48:03 Source File: D:\Games\XBOX\TY_The_Tasmanian_Tiger_NTSC_XBOX-BCG\tyttt-bcg\TY The Tasmanian Tiger NTSC XBOX.iso
I 00:48:03 Source File Sectors: 756,736 (MODE1/2048)
I 00:48:03 Source File Size: 1,549,795,328 bytes
I 00:48:03 Source File File System(s): ISO9660
I 00:48:03 Destination Device: [0:0:0] PIONEER DVD-RW DVR-110D 1.37 (K
(USB)
I 00:48:03 Destination Media Type: DVD-R (Disc ID: MCC 02RG20) (Speeds: 4x, 6x, 8x)
I 00:48:03 Destination Media Sectors: 2,298,496
I 00:48:03 Write Mode: DVD
I 00:48:03 Write Type: DAO
I 00:48:03 Write Speed: 4x
I 00:48:03 Link Size: Auto
I 00:48:03 Test Mode: Yes
I 00:48:03 OPC: No
I 00:48:03 BURN-Proof: Enabled
D 00:48:13 Logical Unit Most Desirable Link Size: 16
D 00:48:13 Device Buffer Size: 1,605,632 bytes.
D 00:48:13 Device Buffer Available: 1,605,632 bytes.
I 00:48:13 Filling Buffer... (40 MB)
I 00:48:13 Writing LeadIn...
I 00:48:33 Writing Session 1 of 1... (1 Track, LBA: 0 - 756735)
I 00:48:33 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 756735)
W 00:51:15 Failed to Write Sectors 438208 - 438239 - Reason: The semaphore timeout period has expired.
W 00:51:15 Retrying (1 of 20)...
W 00:51:16 Retry Failed - Reason: Power On, Reset, or Bus Device Reset Occurred
W 00:51:16 Retrying (2 of 20)...
I 00:51:16 Writing Sectors...
I 00:53:14 Synchronising Cache...
I 00:53:15 Cycling Tray after Test Write...
I 00:53:23 Exporting Graph Data...
I 00:53:23 Graph Data File: C:\Documents and Settings\Desktop\Application Data\ImgBurn\Graph Data Files\PIONEER_DVD-RW_DVR-110D_1.37_FRIDAY-JANUARY-30-2009_12-48_AM_MCC_02RG20_4x.ibg
I 00:53:23 Export Successfully Completed!
I 00:53:23 Operation Successfully Completed! - Duration: 00:05:19
I 00:53:23 Average Write Rate: 5,386 KB/s (3.9x) - Maximum Write Rate: 5,566 KB/s (4.0x)
tinpanalley,
I appreciate the effort, but neither log provided any new useful information.
Since you have a internal sata burner installed, you would be better off getting it to work. In that case, the problem is the software and the burner don't appear to be communicating correctly, which indicates a problem with the cable you're using, the sata controller or its' driver. Have you tried rolling back the sata controller driver in device manager?
1. When I try to roll back the driver for the sata controller, it says there is nothing to roll back to.
2. I've never touched the drive's cables inside the tower.
3. I can't find drivers for this internal drive ANYwhere, much less updated ones. I'm glad I have that Pioneer on its way because this is becoming frustrating.
4. I don't know where to get new SATA controller drivers from. I don't see that on the nvidia site.
Make sure your DISABLE RAID & set SATA to IDE within the mobo BIOS. If this isn't done the SATA dvd burner will NOT WORK CORRECTLY.4. I don't know where to get new SATA controller drivers from. I don't see that on the nvidia site.
Another option would be buying a PCI SATA CONTROLLER CARD that uses the SILICON IMAGE 3114, 3512 CHIPSET for your NVIDIA chipset motherboard.
What is your NVIDIA chipset? NFORCE series 4, 5, 6, 7??????
http://www.nvidia.com/object/nforce_winxp_15.23.html
You would just install the SATAIDE Driver (v10.3.0.42) WHQL
- What is your NVIDIA chipset? NFORCE series 4, 5, 6, 7??????
GeForce 6150SE nForce 430
- Make sure your DISABLE RAID & set SATA to IDE within the mobo BIOS.
Don't know how to do that. Will do research.
- Another option would be buying a PCI SATA CONTROLLER CARD that uses the SILICON IMAGE 3114, 3512 CHIPSET for your NVIDIA chipset motherboard.
Don't know what this means or why this matters. Why would my CPU need a new SATA PCI card if it was sold the way it currently is with SATA ports on the motherboard? Not understanding that.
Thanks again!
Is this one of the enclosures known to have the 80-wire cabling and appropriate chipset, so that it wouldOriginally Posted by lacywest
work with the later burner models ? That issue has come up many times. Such enclosures may still be
in the minority of those being sold -- as surprising as that seems.When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
Best software...........backup my dvds
By wickedbartender in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2010, 05:53 -
Driver backup software
By Tbag in forum ComputerReplies: 2Last Post: 2nd Mar 2010, 18:10 -
Watchmen Backup Issues
By john920 in forum Blu-ray RippingReplies: 4Last Post: 6th Jan 2010, 21:14 -
backup software
By alintatoc in forum ComputerReplies: 21Last Post: 25th Mar 2009, 13:23 -
Data Backup Software
By AuroEdge in forum ComputerReplies: 0Last Post: 26th Sep 2008, 19:48
