VideoHelp.com Forum
    I got a message that the mencoder component needs to be updated/reinstalled...but I can't do it.
    (I downloaded the newer version, "Locate" it and enter my password. Every time I get the error message "The installation was not successful. Improper use of the sudo command can lead to data loss... etc. etc.")
    How do you do this?
  2. Explorer Case's Avatar
    Perhaps you have special characters in your password, or you are not logged in with an account that has admin privileges? That could be a cause of a failed binaries installation.
    I don't have a password (got tired of typing it when installing updates) and I am definitely using the administrator account (don't really *ever* use the one guest account).
  4. Explorer Case's Avatar
    The lack of a password is the problem. The installer tries to use the sudo command in the background. That won't work with a blank password.
    Set a password for the installation. Change it back to blank afterwards, if you must.
  1. component install trouble
    By threelibr3s in forum ffmpegX general discussion
    Last Post: 28th Oct 2008, 12:30
  2. Replies: 1
    Last Post: 10th Jun 2008, 18:20
  3. Replies: 2
    Last Post: 5th Apr 2008, 13:43
  4. HDMI vs Component.....
    By snadge in forum DVB / HDTV
    Last Post: 27th Feb 2008, 17:02
