I am trying to burn a dvd disk from an mkv file but when I try to load it I get an error box : Unsupported format
This tracks was ignored ...\filename.mkv
I end up with just one file with H.264 in the codec column and High@5.1 etc in the profile column. Am I correct in assuming that this has not picked up any audio track?
Results 1 to 9 of 9
Thread: Problems with TsMuxer
carpe diem maņana
What is the audio in your mkv file? Identify using MediaInfo.
I have downloaded it but can'ty work out how to use it? Sorry for being thick!
carpe diem maņana
In Mediainfo open your mkv, change to view->text, copy all the text and paste here in this topic.
When I click on Mediainfo I get a very quick black run screen which disappears. Which file do I click to make it run please?
carpe diem maņana
Download the mediainfo gui and it will work beetter, http://www.videohelp.com/download/Me...ndows_i386.exe
eneral
Complete name : C:\Documents and Settings\Administrator\My Documents\Downloads\Compressed\Spiderman 3\Spiderman 3.mkv
Format : Matroska
File size : 1.46 GiB
Duration : 2h 19mn
Overall bit rate : 1 498 Kbps
Movie name : Spider-Man 3
Encoded date : UTC 2008-01-29 10:54:19
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Cover : Yes
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 19mn
Nominal bit rate : 1 306 Kbps
Width : 720 pixels
Height : 352 pixels
Display aspect ratio : 2.479
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.215
Title : Movie
Writing library : x264 core 57 svn-709C
Encoding settings : cabac=1 / ref=6 / deblock=1:0:-1 / analyse=0x3:0x133 / me=hex / fpel_cmp=sad / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=1 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=30 / direct=3 / wpredb=1 / bime=1 / keyint=480 / keyint_min=24 / scenecut=40(pre) / rc=2pass / bitrate=1306 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=192628,200228,b=0.1
Language : English
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : No
Codec ID : A_AAC
Duration : 2h 19mn
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 16 bits
Title : Nero AAC 6ch Audio
Language : English
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Title : Subtitle
Language : Englishcarpe diem maņana
AAC audio wont work if you want blu-ray video and the resolution is not supported either. But why make a blu-ray when it's just standard video(720x352)?
Just buy/rent spiderman 3 on dvd or blu-ray instead.
more MultiAVCHD/tsmuxer problems
By tailz in forum Authoring (Blu-ray)Replies: 8Last Post: 10th Feb 2012, 12:24 -
Help with tsMuxer!!
By BIGD22 in forum Blu-ray RippingReplies: 5Last Post: 29th Oct 2011, 21:01 -
tsMuxer Help Please!!!
By zzNyQuilzz in forum Video ConversionReplies: 3Last Post: 26th Sep 2011, 08:17 -
tsmuxer help
By magmo in forum Blu-ray RippingReplies: 1Last Post: 20th Jul 2009, 04:35 -
Problems with subtitles using tsMuxer
By cruck in forum Authoring (Blu-ray)Replies: 3Last Post: 7th May 2009, 02:11
