VideoHelp.com Forum
    I was extremely grateful to find this guide but after following all the instructions very closely I was left with a file that was still apparently PAL. Please excuse me for I'm far from an expert, and probably in the dumbass category in terms of computer know how on this board. Anyway, I for some reason I was left with a file that didn't have the correct dimensions, I think, even though my script was fine. But more importantly, the guide doesn't say to change the frame rate from PAL anywhere until the use of pulldown. My guess is that this should have been down using CCE. So, my question is I suppose, is my guess correct? Or if not, is the guide in fact perfectly fine? What do I need to do differently or is it just a matter of learning how to read? Thanks for your help.
  2. I'm a Poll Super Moderator johns0's Avatar
    Not sure what guide you are using but if you are encoding pal to ntsc you change the frame size from 720x576 to 720x480 and leave the fps at 25 and when finished encoding you run the finished mpv through dgpulldown at
    25-->29.97.
    Ben Johnson-I didnt take any stereos!
  3. Yeah, what guide is this?
    If it's this one:
    http://www.eggshellskull.com/pal2ntsc/
    then the guide is no good in more ways than one, but he's using an older version of CCE. My educated guess is that you didn't uncheck the "For DVD" box near the top of the main screen of CCE. It will override your AviSynth script since you set it for 25fps, and also give you a PAL resolution. Uncheck the box. In the guide writer's defense, I don't believe the version of CCE he used had that same checkbox.
  1. converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
    By extent in forum Newbie / General discussions
    Last Post: 11th Jun 2010, 12:38
  2. ".mkv" to "DVD" with CCE encoder
    By chrchr in forum Authoring (DVD)
    Last Post: 28th Jan 2010, 13:01
  3. Replies: 14
    Last Post: 31st Oct 2009, 09:31
  4. couple "playing Pal in Ntsc" questions
    By spiritgumm in forum Newbie / General discussions
    Last Post: 16th Mar 2009, 20:34
  5. CCE guide for PAL to NTSC conversion
    By alexs_eu in forum Video Conversion
    Last Post: 21st Jun 2008, 07:41
