I was capturing from a vhs tape to dvd, using my dvd recorder. The video tape is old, and the vcr i am using, JVC HR-S7600U, has a function called "video calibration". I had that turned on, and when it got to a bad part of the tape, the vcr turned that function on. On the screen, it said "calibrating video" or something. I know that virtualdub has a filter to remove network logos. Can i use such a filter to remove the text "calibrating video" from the screen, or would it be difficult?
thanks
You can use these filters to turn the text into a pixelly blur, but unlikely to really remover it. Do a search through the forums for delogo and you will find several posts that have lots of details and discussions
Cool, i will find the posts! thanks for the tip!
Remove duplicate text from SRTs
By cal_tony in forum SubtitleReplies: 7Last Post: 9th Feb 2012, 21:49 -
How do I remove unwanted text in movie
By rocks911 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2011, 10:35 -
Remove text from file properties
By Pegsitron in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2010, 07:29 -
How to remove text from MKV?
By Lastbreath in forum EditingReplies: 1Last Post: 2nd May 2010, 04:34 -
remove text while converting?
By aussiemac in forum Video ConversionReplies: 2Last Post: 18th Aug 2007, 21:29
Statistics
Newest guides
Latest tool updates
New media comments
