VideoHelp.com Forum
    What does it mean when it shows a number of frames dropped at the bottom of the WinDV window during a capture? It looks like the capture keeps on going and video is not lost?
  2. your computer isn't keeping up with the transfer. enough dropped frames and you will notice the video skipping. try disabling anything using the hard drive or cpu during capture, including anti-virus that may be real time inspecting the file.
    Still dropping, but starts doing it everytime when the file gets to:
    2.61 GB
    12min 30 time
    Bit rate of 1024kbps
    dim 720x480
    The WinDV config frame stop is set at 22500. Can I adjust the frame stop so it cuts off the capture before the 12:30 or 2.61 GB and automatically starts another file?
    Thanks in advance.
    You can adjust it to stop where ever you please. The question is why is it dropping at that point. Is there an issue with the tape ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Tapes are fine. It looks like it is just doing it on my high8 tapes. When I hook my miniDV tapes up, WinDV automatically creates new, smaller folders. I guess I will just have to start and stop the high8's manually.
    Another question - the captured AVI videos look cloudy/milky. Is that just because they are on my PC? Will they look better once I create movies and download to DVD?
  1. Replies: 12
    Last Post: 17th Aug 2011, 22:33
  2. WinDV dropped frames - SOME camcorders, not all?!
    By 2Bdecided in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 11th Mar 2010, 03:44
  3. Replies: 13
    Last Post: 9th Apr 2009, 16:25
  4. Replies: 9
    Last Post: 3rd Dec 2007, 13:39
  5. Replies: 0
    Last Post: 23rd Aug 2007, 20:59
