VideoHelp.com Forum
    Hi
    When I run the latest version of RipBot264 in Vista I run in to trouble. I have diabled UAC and run the ripbot264 application as a administrator but I still get the "DirectShowSource: Couldn't open C:\temp\RipBot264temp\job1\video.mkv:
    The selected folder/file was not found
    (C:\temp\RipBot264temp\job1\getinfo.avs, line 2)" error when I try to convert m2ts to mkv files. Therefore I used TsMuxer instead to create ts files and the used them inside ripbot264. That worked fine, but I need the subtitles also. Previously when I ran a "m2ts to mkv " conversation a folder in c:\temp was created and inside that folder a *.sup file was created that I could use to create a srt file. But wjen I run the "ts to mkv" conversation no such folder or file is created in c:\temp. Are they created somewhere else or how do I get subtitles when converting from ts to mkv?
    You can extract the subtitles using tsmuxer also.
    But TsMuxer create one meta file and one ts file, Suprip needs the *.sup file, how can I get a sup file from TsMuxer?
    I have the same trouble what magmo has. Also i create .m2ts file to .ts file using TxMuxer and tried RipBot264 again but it is still doesn't working. I thought that just Vista does this trouble but i also tried Xp and i had the same trouble. I don't know what to do while converting .m2ts files to .mkv I used XviD4PSP before to convert .m2ts to .mkv x264 but it takes to long like days. And take program use memory and cpu too muck. I can't use my computer before XviD4PSP finish the converting.
    Note: My computers property is core 2 duo T9400 2.53 ghz and 4 gb ddr2 ram, vista 32 bit
    aa
  1. Occasional Sound issues with a burnt DVD
    By Al Slitter in forum Newbie / General discussions
    Last Post: 17th Dec 2011, 17:45
  2. Replies: 2
    Last Post: 13th Nov 2011, 22:20
  3. Encoding Blu-ray to Mp4 with RipBot Trouble
    By F.Garvin in forum Blu-ray Ripping
    Last Post: 2nd Nov 2010, 22:30
  4. Occasional D.O.A. slideshows made with Proshow Gold
    By Seeker47 in forum Authoring (DVD)
    Last Post: 25th Nov 2007, 18:33
  5. Replies: 18
    Last Post: 27th Oct 2007, 12:01
