does anyone know if it is possible to replace the burner with a standard gsa-10N type of PC burner?
Friend has one and the burner has dies.
Thanks everyone.
Thread: lg lrh-539 with hard drive
I've read of some being swapped (don't know if they were the same brand/model). You should be able to tell by simply opening it up and looking. I also seem to recall that you couldn't use just any drive as a replacement. So you may need to track down an identical drive or just by trial and error.
Google is your Friend
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
LG LRH-780 DVD Drive Problems..... Solved!
By dragon064 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Feb 2010, 19:59 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06
Statistics
Newest guides
Latest tool updates
New media comments
