VideoHelp.com Forum
    hey guys, im new to this and i would like to get mediainfo to export exactly the following info from a video
    General
    Complete name                    : name.mp4
    Format                           : MPEG-4
    Format profile                   : Base Media / Version 2
    Codec ID                         : mp42
    File size                        : 40.6 MiB
    Duration                         : 4mn 42s
    Overall bit rate                 : 1 204 Kbps
    Video
    Bit rate mode                    : Variable
    Bit rate                         : 1 012 Kbps
    Width                            : 832 pixels
    Height                           : 528 pixels
    Display aspect ratio             : 1.576
    Frame rate mode                  : Constant
    Frame rate                       : 23.981 fps
    Resolution                       : 24 bits
    Audio
    Format                           : AAC
    Bit rate mode                    : Constant
    Bit rate                         : 192 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 48.0 KHz
    Resolution                       : 16 bits
    Stream size                      : 6.34 MiB (16%)
    can anyone help me out, i tried by reading the help but it was just caos!
    thanks in advanced
  2. looks like the display you get if you click view/text
    View -> text.
    yes put it comes with a lot more info
    and i want just to have whats posted on the first post
  5. the text display is not customizable.
  6. Member MysticE's Avatar
    Use GSpot instead. You can customize it's reports. You'll need to make your own template (with HTML code). Look under Export -> Enable export-> Custom.
    Look in ExportFormat.txt for details on how to set up your template.
    thank you everyone, i will give ir a try!
  1. Calling MediaInfo from Visual Basic to et video info
    By SearchQuality in forum Programming
    Last Post: 2nd Nov 2011, 06:36
  2. Edit MediaInfo Info
    By thezanny in forum Newbie / General discussions
    Last Post: 13th Aug 2011, 04:18
  3. Replies: 4
    Last Post: 6th Jun 2010, 12:16
  4. Mediainfo File Info tool "Format Profile" wrong info problem
    By dabas in forum Newbie / General discussions
    Last Post: 9th Mar 2010, 05:07
  5. Cyclone Sumvision display info please
    By paul dj in forum Newbie / General discussions
    Last Post: 9th Aug 2009, 13:34
