Does AutoGK support DTS? I'm using v2.50alpha
Ripped with AnyDVD 6.5.0.7
AutoGK shows two audio streams:
Audio stream 0 AC
Audio stream 1 DTS
I select DTS and start encoding. After a minute or so it quits, saying it cannot find audio. "agk_tmp" folder only contains .d2v file.
I select BOTH DTS and AC3 and start encoding. After a minute or so it quits again, saying the same thing. but this time I get .d2v file and a ac3 file (VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.ac3)
Here is the log file:
[2009-01-07 4:05:57] AutoGK 2.50a
[2009-01-07 4:05:57] OS: Windows Vista (6.0.6001).2
[2009-01-07 4:05:57] Job started.
[2009-01-07 4:05:57] Input file: D:\Ripped\MainMovie\movietitle\VIDEO_TS\VTS_01_1.VOB
[2009-01-07 4:05:57] Output file: D:\Ripped\MainMovie\movietitle\VIDEO_TS\VTS_01_1.avi
[2009-01-07 4:05:57] Output codec: XviD
[2009-01-07 4:05:57] Audio 1: Audio Stream 1 DTS
[2009-01-07 4:05:57] Audio 2: Audio Stream 0 AC3
[2009-01-07 4:05:57] Subtitles: none
[2009-01-07 4:05:57] Format: AVI
[2009-01-07 4:05:57] Target size: 2500Mb
[2009-01-07 4:05:57] Custom resolution settings: fixed width of 800 pixels
[2009-01-07 4:05:57] Audio 1 settings: Original
[2009-01-07 4:05:57] Audio 2 settings: Original
[2009-01-07 4:05:57] Started encoding.
[2009-01-07 4:05:57] Demuxing and indexing.
[2009-01-07 4:07:05] Processing file: D:\Ripped\MainMovie\movietitle\VIDEO_TS\VTS_01_1.VOB
[2009-01-07 4:07:05] Processing file: D:\Ripped\MainMovie\movietitle\VIDEO_TS\VTS_01_2.VOB
[2009-01-07 4:07:05] Processing file: D:\Ripped\MainMovie\movietitle\VIDEO_TS\VTS_01_3.VOB
[2009-01-07 4:07:05] Processing file: D:\Ripped\MainMovie\movietitle\VIDEO_TS\VTS_01_4.VOB
[2009-01-07 4:07:05] Processing file: D:\Ripped\MainMovie\movietitle\VIDEO_TS\VTS_01_5.VOB
[2009-01-07 4:07:05] Processing file: D:\Ripped\MainMovie\movietitle\VIDEO_TS\VTS_01_6.VOB
[2009-01-07 4:07:05] Source resolution: 720x480
[2009-01-07 4:07:05] Found NTSC source.
[2009-01-07 4:07:05] Source aspect ratio: 16:9
[2009-01-07 4:07:05] Source seems to be pure FILM.
[2009-01-07 4:07:06] Output will contain 162288 frames
EXCEPTION: Audio is not found.
[2009-01-07 4:07:06] Job finished. Total time: 1 minute, 8 seconds
Are there any additional steps I left out?
adding dts audio stream to DVD folder
By medo_256 in forum Newbie / General discussionsReplies: 56Last Post: 6th Jun 2010, 06:54 -
DTS audio stream not recognized in m2ts playback w/ PowerDVD or PVRX2
By bigshotceo in forum Software PlayingReplies: 0Last Post: 9th Feb 2010, 09:45 -
Exception: Audio is not found [AutoGK]
By corn in forum DVD RippingReplies: 2Last Post: 3rd Sep 2009, 00:57 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 17:42 -
Clicks in DTS audio stream in MKV file
By MisterB42 in forum AudioReplies: 0Last Post: 23rd Aug 2007, 17:25
Statistics
Newest guides
Latest tool updates
New media comments
