Hi there I have a mkv file that i have put through tsmuxer and i am having trouble playing on my pioneer bdplx70a. when i try playing it recognises its a avchd disc but then just says "resume off" and wont play.....
It was processed through tsmuxer at 4.1 which was default...would this be too high???? I have done a previous file at 3.1 and it worked ok, but whats the difference..
Hope someone can help as im running out of dual layer discs lol
Thread: mkv to avchd trouble
Is the mkv file blu-ray compliant then? like video frame size/resolution, video codec and audio codec.
Use mediainfo to identify the settings and post here.
Thanks for the reply baldrick
video
profile:high@4.1 resolution 1280:528p frame rate 23.976
audio
bitrate: 640kbps sample rate 48khz channels:6
1280x528 is not blu-ray compliant so it may be because of that. Try reconvert with blackborders to 1280x720p(or 1920x1080). Use for example Ripbot264.
http://www.videohelp.com/hd#tech
Not sure if its allowed to discuss in these forums too much but I want to see what the fuss is about with these new blueray rips x264 and this is just a sample..
Just buy/rent your blu-rays and they will work perfect...
Help with BD-P1500 and mkv via AVCHD
By Syco54645 in forum DVD & Blu-ray PlayersReplies: 48Last Post: 10th Oct 2010, 06:12 -
AVCHD to MKV 5.1 Ripping
By amitabhbansal in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 03:33 -
Mkv avchd pointers
By romanticwarrior in forum Authoring (Blu-ray)Replies: 5Last Post: 7th Sep 2010, 17:57 -
mov to mkv/avchd
By nirbhayn in forum Video ConversionReplies: 1Last Post: 19th Jun 2009, 14:33 -
Converting Mkv to AVCHD
By ranosb in forum Video ConversionReplies: 1Last Post: 9th May 2009, 05:25
