VideoHelp.com Forum
    Hi
    Can anyone help with the following.
    I trying to find a Visioneer 4800 USB Scanner driver
    Developer: Visioneer
    System: Windows XP,Windows Vista,Windows 3.11,Windows 2000 SP3,Windows 2000 SP2,DOS,Windows 2000 SP4,Windows NT,Windows 98 SE,Windows 2000 SP1,Windows 2000,Windows NT SP3,Windows ME
    Thanks in advance
    Thanks Krispy Kritter
    I have Vista. This is for For Windows 98/ME/2000/xp
  3. Member Krispy Kritter's Avatar
    Sorry, that wasn't obvious from your initial post. If the XP drivers don't work, your only option is to contact the vendor. As they obvously haven't posted any updated drivers, they will either have a work around or won't support Vista. In which case you will need to get a new scanner.
    The joys of upgrading and trying to use old hardware.
    Google is your Friend
  4. Member ahhaa's Avatar
    T- if you simply google Visioneer 4800 USB Scanner driver, you will see just about every such link
    on the web...
    also, somewhat amazingly...
    ReQ: Visioneer 4800 USB Scanner Driver - VideoHelp.com
    Jan 7, 2009 ... I trying to find a Visioneer 4800 USB Scanner driver. Developer: Visioneer System: Windows XP,Windows Vista,Windows 3.11,Windows 2000 SP3 ...
    forum.videohelp.com/topic362232.html - Similar pages
    ahhaa
    on the web...
    That was the first thing i did. But no luck! Thats why i posted on videohelp.com. As you know you always get good advice from guys on videohelp.com
    Thanks for the reply.
  6. Member classfour's Avatar
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  7. Member Krispy Kritter's Avatar
    Originally Posted by classfour
    http://support.visioneer.com/UK/products/home/EOL/4800/downloads.asp
    Those are also only XP drivers.
  1. Replies: 4
    Last Post: 21st Nov 2010, 22:22
  2. Replies: 2
    Last Post: 6th Mar 2010, 14:06
  3. Visioneer 4400 USB scanner
    By kenmo in forum Linux
    Last Post: 28th Oct 2009, 13:16
  4. Replies: 6
    Last Post: 13th Feb 2008, 12:58
  5. Help with USB driver for Panasonic PV-GS120 miniDV
    By bowmah in forum Newbie / General discussions
    Last Post: 2nd Jan 2008, 15:31
