VideoHelp.com Forum
    Hi Guys, I just purchased Western Digital WD TV HD Media Player . I have been trying to setup universal remote with this product , does any one know what is the code for it .I have tried google but no luck so far , or do i have to buy one of those logitech harmoney remotes or I can my Samsung universal remote that came with my TV .
  2. Member Krispy Kritter's Avatar
    Contact the manufacturer of the universal remote that you are using. If there is a code, they should be able to supply it to you. Keep in the mind the WD units are new, so any older remotes likely won't have any codes. The Logitech units should work as the programming is done on the PC using a code database maintained by Logitech.
    Google is your Friend
    Thanks for the info
    I sprung for the $20 + S&H for the New Dishnetwork learning remote 21.0 IR/UHF Pro.
    Right out of the Box it gave all my HD DVR functions. TV Ditto.
    Programmed the Aux button for the input switching and volume on myTV, Input switching and Audio on my Surround sound system. So using the AUX button on it I can do all I need to enjoy the WDTV with one remote and no switching back and forth between TV, Sound system and WDTV player.
    I still haven't decided whether to program the DVD buttons for my changer or My Phillips 5990 or Philips/Pioneers DVD recorder.
    I guess the harmony remotes are nice but for <$30 I do all I needed.
    Anyway that was my Solution.
    Cheers
    Cheers
    thanks thats all I needed , just the name of the remote that worked for someone.I really enjoy my WDTV I would hate to loose it cause of sucky remote.
  1. Replies: 4
    Last Post: 31st Jul 2011, 02:38
  2. Western Digital Media Player Thumbnail help
    By DebCoom in forum Media Center PC / MediaCenters
    Last Post: 19th Feb 2011, 07:06
  3. Western Digital TV Live HD Media Player
    By dvdsham in forum Newbie / General discussions
    Last Post: 1st May 2010, 22:32
  4. Menu for DVDs with Western Digital Media Player Live?
    By craigwojo in forum Video Conversion
    Last Post: 6th Dec 2009, 23:01
  5. Western Digital HD MEdia Player alternatives?
    By peggypwr1 in forum Newbie / General discussions
    Last Post: 28th Feb 2009, 15:15
