Afternoon All,
Here I am, back againWas wondering if anyone could help me with a problem I am having. I have transferred a program from my Humax PVR to my laptop with a view to putting it on the DVD. I have run the .ts file from the PVR through MPEG Stream Clip to get an MPEG file, and am trying to burn that to DVD using AvsToDVD. However, the latter aborts about halfway through the process and says I should check a couple of log files. I have pasted these log files below. I can view the MPG with VLC no problems, but for some reason AvsToDVD is failing to burn it.
Firstly, the AvsToDVD log:
<06-01-2009 10:27:57>
START PROCESS
DVD SETTINGS
DVD Titles number: 1
DVD Video Standard: PAL
DVD Chapters Interval: 5 min
DVD Menu: Static DVD Menu
DVD Label: Saints v Scarlets 1 Nov 08
DVD Burning Drive: D:\
DVD Burning Speed: 2x
DVD Size: 4101/4435 MB (92%)
DVD Output Setup: Burn DVD
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Save Log file: Yes
Output Folder: C:\Documents and Settings\Administrator\My Documents
TITLE 1 SOURCE FILES
Video: C:\Documents and Settings\Administrator\My Documents\My Videos\Saints v Scarlets 1 Nov 08.mpg
Info: MPEG-2 Video - 4511 kbps - 720x576 - DAR 1.778 - 25 fps - TFF - 1:58:49 hours - 178244 frames
Audio: C:\Documents and Settings\Administrator\My Documents\My Videos\Saints v Scarlets 1 Nov 08.mpg
Info: MPEG-1 Audio layer 2 - 256 kbps - CBR - 48000Hz - 2ch - 1:58:49 hours
Subs:
[MediaInfoLib - v0.7.7.8]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Saints v Scarlets 1 Nov 08.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
Video = Video.ConvertToYV12
Video = Video.Lanczos4Resize(720,576)
Audio = A2DAudioSource("C:\Documents and Settings\Administrator\My Documents\My Videos\Saints v Scarlets 1 Nov 08.mpg", CacheFolder = "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp")
AudioDub(Video, Audio)
START VIDEO DEMUXING OPERATIONS
Target Video FileSize: 3834.2 MB
ReJig Parameters: -level 100 -o "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.m2v" -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Saints v Scarlets 1 Nov 08.mpg" -auto -close
<06-01-2009 10:36:46>
END VIDEO ENCODING OPERATIONS
Created File: C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.m2v (3605.5 MB)
<06-01-2009 10:36:47>
OUTPUT VIDEO INFO:
Filename: Saints v Scarlets 1 Nov 08_1_Title_01
Filesize: 3780604029 Byte
Format: MPEG Video
Time: 0 seconds
Compression: MPEG-2 Video
AvgBitRate: 63010067
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: TFF
Frames: 12
START AUDIO ENCODING OPERATIONS
QuEnc (Audio) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Title_01.avs" -o "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.ac3" -priority 5 -1 -nohq -novbr -mpeg2mux novideo -audiocodec AC3 -audiobitrate 192 -auto -close
<06-01-2009 10:57:54>
END AUDIO ENCODING OPERATIONS
Created File: C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.ac3 (154.6 MB)
<06-01-2009 10:57:57>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_BatchMux.ini"
BatchMux ini file:
-d "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1\VIDEO_TS"
-mxp "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_MuxMan.mxp"
-l "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.ac3"
-a1lang en
-cellfr "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Title_01_MuxMan.txt"
-progfr "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Title_01_MuxMan.txt"
-chapfr "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Title_01_MuxMan.txt"
-SEG2v "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Menu.bmp"
-SEG2vidmode LB
-SEG2s1 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Menu.sst"
-SEG2s1dmode WIDE_LB
-SEG2hlmnu "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Buttons.mnu"
-SEG2hlcsm "C:\Program Files\AVStoDVD\Menu\Highlight_Scheme.csm"
-hcn "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_BatchMux.hcn"
<06-01-2009 13:18:49>
PROCESS ABORTED DURING DVD AUTHORING FINALIZATION!
CHECK FOLLOWING FILES FOR MORE DETAILS:
AVSTODVD LOG FILE <C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\MY DOCUMENTS\SAINTS V SCARLETS 1 NOV 08_1.LOG>
BATCHMUX LOG FILE <C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\MY DOCUMENTS\SAINTS V SCARLETS 1 NOV 08_1_BATCHMUX.LOG>
<06-01-2009 13:18:52>
Log file created by AVStoDVD Release 2.1.2
and the BatchMux log:
BatchMux version --> 1.3
Destination Folder --> C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1\VIDEO_TS
MuxMan Script File --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_MuxMan.mxp
MuxMan Log String --> -l "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_MuxMan.log"
Folder of the MuxMan executable --> C:\Program Files\AVStoDVD\MuxMan
Check presence of MuxMan.exe --> PASSED
Segment #1 - Video File #1 --> C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.m2v
Checking asset for importing as --> M2V, M1V, MPV
Video Coding Mode --> MPEG-2
Video Resolution (Nominal) --> (720x576)
MPEG-2 Aspect Ratio (DAR) --> 16:9
Video Frame Rate --> 25 fps
Video Bitrate (Nominal, Kbps) --> 7812
VBV Buffer Size (Kbyte) --> 224
Segment #1 - Video Display Mode --> LB
Segment #1 - Audio #1 File #1 --> C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.ac3
Segment #1 - Audio Lang Code #1 --> en
Segment #1 - Timeframe file --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Title_01_MuxMan.txt
Segment #1 - Total Nr of Cells --> 24
Segment #1 - Total Nr of Programs --> 24
Segment #1 - Total Nr of Chapters --> 24
Segment #2 - Video File #1 --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Menu.bmp
Checking asset for importing as --> BMP
Image size --> (720x576)
Image asset --> ACCEPTED
Segment #2 - Video Display Mode --> LB
Segment #2 - Subpicture File #1 --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Menu.sst
Segment #2 - Subpic Disp Mode #1 --> WIDE_LB
Segment #2 - HL Play Item #1 MNU File --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Buttons.mnu
Segment #2 - HL Play Item #1 NumButtons --> 2
Segment #2 - HL Play Item #1 NumGroups --> 2
Segment #2 - HL Play Item #1 G1 Button Mode --> WIDE
Segment #2 - HL Play Item #1 G2 Button Mode --> LB
Imported Butt1 G1 posx --> 272
Imported Butt1 G1 posw --> 176
Imported Butt1 G1 posy --> 204
Imported Butt1 G1 posh --> 142
Imported Butt1 G1 adj_but_up --> 1
Imported Butt1 G1 adj_but_left --> 1
Imported Butt1 G1 adj_but_right --> 2
Imported Butt1 G1 adj_but_down --> 2
Imported Butt1 G1 color scheme --> 1
Imported Butt1 G1 auto activate --> 0
Imported Butt1 G1 command --> 71 04 00 00 00 01 00 02
Button command interpreted as --> mov GPRM0, 1 ; LinkPGCN __CURRENT_DOMAIN_PGC__2
Imported Butt1 G2 posx --> 272
Imported Butt1 G2 posw --> 176
Imported Butt1 G2 posy --> 225
Imported Butt1 G2 posh --> 107
Imported Butt1 G2 adj_but_up --> 1
Imported Butt1 G2 adj_but_left --> 1
Imported Butt1 G2 adj_but_right --> 2
Imported Butt1 G2 adj_but_down --> 2
Imported Butt1 G2 color scheme --> 1
Imported Butt1 G2 auto activate --> 0
Imported Butt1 G2 command --> 71 04 00 00 00 01 00 02
Imported Butt2 G1 posx --> 570
Imported Butt2 G1 posw --> 102
Imported Butt2 G1 posy --> 482
Imported Butt2 G1 posh --> 45
Imported Butt2 G1 adj_but_up --> 1
Imported Butt2 G1 adj_but_left --> 1
Imported Butt2 G1 adj_but_right --> 2
Imported Butt2 G1 adj_but_down --> 2
Imported Butt2 G1 color scheme --> 1
Imported Butt2 G1 auto activate --> 0
Imported Butt2 G1 command --> 71 04 00 00 00 01 00 02
Imported Butt2 G2 posx --> 570
Imported Butt2 G2 posw --> 102
Imported Butt2 G2 posy --> 434
Imported Butt2 G2 posh --> 34
Imported Butt2 G2 adj_but_up --> 1
Imported Butt2 G2 adj_but_left --> 1
Imported Butt2 G2 adj_but_right --> 2
Imported Butt2 G2 adj_but_down --> 2
Imported Butt2 G2 color scheme --> 1
Imported Butt2 G2 auto activate --> 0
Imported Butt2 G2 command --> 71 04 00 00 00 01 00 02
Segment #2 - HL Play Item #1 Force Selected Button Nr --> 2
Segment #2 - HL Play Item #1 Force Activated Button Nr --> 0
Segment #2 - HL Play Item #1 Selection End Time --> -1
Segment #2 - HL Play Item #1 Nr of Selectable Buttons --> 2
Segment #2 - HL Play Item #1 Color Scheme File --> C:\Program Files\AVStoDVD\Menu\Highlight_Scheme.csm
Imported CSM #1 Select Color --> (E2 E1 PA BG) 6 6 6 6
Imported CSM #1 Select Opacity --> (E2 E1 PA BG) 0 2 4 8
Imported CSM #1 Action Color --> (E2 E1 PA BG) 1 1 1 1
Imported CSM #1 Action Opacity --> (E2 E1 PA BG) 0 3 6 12
Imported CSM #2 Select Color --> (E2 E1 PA BG) 0 0 0 0
Imported CSM #2 Select Opacity --> (E2 E1 PA BG) 0 0 0 0
Imported CSM #2 Action Color --> (E2 E1 PA BG) 0 0 0 0
Imported CSM #2 Action Opacity --> (E2 E1 PA BG) 0 0 0 0
Imported CSM #3 Select Color --> (E2 E1 PA BG) 0 0 0 0
Imported CSM #3 Select Opacity --> (E2 E1 PA BG) 0 0 0 0
Imported CSM #3 Action Color --> (E2 E1 PA BG) 0 0 0 0
Imported CSM #3 Action Opacity --> (E2 E1 PA BG) 0 0 0 0
Configuration File for HCN --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_BatchMux.hcn
HC Navigation - VMG MenuPages --> 1
HC Navigation - VMG MenuType(1) --> STATIC
HC Navigation - VMG TitleBut(1) --> 1
HC Navigation - VMG PlayAllBut(1) --> 2
Started preparation of --> MUXMAN SCRIPT
Completed preparation of --> MUXMAN SCRIPT
MuxMan RunString --> -run
Strings (local stack - bytes) --> 1812
Time Codes (local heap - bytes) --> 877
Static memory usage % --> 2.05
Starting MuxMan Authoring with --> LOW task priority
MuxMan Authoring --> COMPLETE
Printing out --> MUXMAN LOG
-- MuxMan version 0.15R
-- Opened script file C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_MuxMan.mxp
-- Accepted video C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.m2v size = 3780604029
-- Accepted audio C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_1_Title_01.ac3
-- Accepted image C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Menu.bmp
-- Opened sub 1 file C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_1_Menu.sst.
-- expanded database to 300 entries.
-- No useable audio found for PGC "VMG_Lu1_Pgc1"
-- 11:05:34 Begin multiplex VTS01.
-- Title Segment List
-- Seg1
-- Maximum audio duration 337794 fields.
-- Starting scene Seg1_Scn1 at 00:00:00:00
-- Starting scene Seg1_Scn2 at 00:05:00:10, requested for 00:05:00:00
-- Starting scene Seg1_Scn3 at 00:10:00:10, requested for 00:10:00:00
-- Starting scene Seg1_Scn4 at 00:15:00:10, requested for 00:15:00:00
-- Starting scene Seg1_Scn5 at 00:20:00:10, requested for 00:20:00:00
-- Starting scene Seg1_Scn6 at 00:25:00:10, requested for 00:25:00:00
-- Starting scene Seg1_Scn7 at 00:30:00:10, requested for 00:30:00:00
-- Starting scene Seg1_Scn8 at 00:35:00:10, requested for 00:35:00:00
-- Starting scene Seg1_Scn9 at 00:40:00:10, requested for 00:40:00:00
-- Starting scene Seg1_Scn10 at 00:45:00:10, requested for 00:45:00:00
-- Starting scene Seg1_Scn11 at 00:50:00:10, requested for 00:50:00:00
-- Starting scene Seg1_Scn12 at 00:55:00:10, requested for 00:55:00:00
-- Starting scene Seg1_Scn13 at 01:00:00:10, requested for 01:00:00:00
-- Starting scene Seg1_Scn14 at 01:05:00:10, requested for 01:05:00:00
-- Starting scene Seg1_Scn15 at 01:10:00:10, requested for 01:10:00:00
-- Starting scene Seg1_Scn16 at 01:15:00:10, requested for 01:15:00:00
-- Starting scene Seg1_Scn17 at 01:20:00:10, requested for 01:20:00:00
-- Starting scene Seg1_Scn18 at 01:25:00:10, requested for 01:25:00:00
-- Starting scene Seg1_Scn19 at 01:30:00:10, requested for 01:30:00:00
-- Starting scene Seg1_Scn20 at 01:35:00:10, requested for 01:35:00:00
-- Starting scene Seg1_Scn21 at 01:40:00:10, requested for 01:40:00:00
-- Starting scene Seg1_Scn22 at 01:45:00:10, requested for 01:45:00:00
-- Starting scene Seg1_Scn23 at 01:50:00:10, requested for 01:50:00:00
-- End of video file
-- Bytes remaining in buffer = 0.
-- Bitrate - avg: 4773738, min: 3174400 (lba 630963), max: 6280533 (lba 933152).
-- Shortest GOP has 20 fields, longest GOP has 24 fields.
-- Fields: 337816, VOBU: 14076, Sectors: 1968561.
-- Reference to non-existant scene "Seg1_Scn24" from PGC "VTS01_Ttn1_Pgc1"
Segment memory resources --> RELEASED
Local Stack memory --> RELEASED
File i/o structures --> DEALLOCATED
Does this mean anything to anyone?
Thanks,
Al.
Results 1 to 26 of 26
Hi Al,
there is a problem in chapters assignement when dealing with demuxed mpeg2 streams. It should have been fixed with release 2.1.3 Alpha. Give a try to it.
Let me know
Bye -
Thanks for your prompt response, MrC. I will try the new version tomorrow and let you know how I get on.
Al. -
I tried the version you suggested and got the same problem, log files below in case they're different. Any thoughts??Originally Posted by _MrC_
Destination Folder --> C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2\VIDEO_TS
MuxMan Script File --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_MuxMan.mxp
MuxMan Log String --> -l "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_MuxMan.log"
Segment #1 - Video File #1 --> C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.m2v
Segment #1 - Audio #1 File #1 --> C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.ac3
Segment #1 - Timeframe file --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Title_01_MuxMan.txt
Segment #2 - Video File #1 --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Menu.bmp
Segment #2 - Subpicture File #1 --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Menu.sst
Segment #2 - HL Play Item #1 MNU File --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Buttons.mnu
Configuration File for HCN --> C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_BatchMux.hcn
-- Opened script file C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_MuxMan.mxp
-- Accepted video C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.m2v size = 3723230863
-- Accepted audio C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.ac3
-- Accepted image C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Menu.bmp
-- Opened sub 1 file C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Menu.sst.
-- 10:19:47 Begin multiplex VTS01.
-- Seg1
-- Maximum audio duration 337796 fields.
-- Bitrate - avg: 4705128, min: 3174400 (lba 621511), max: 6280533 (lba 919943).
-- Fields: 337816, VOBU: 14076, Sectors: 1940268.
<07-01-2009 09:45:14>
START PROCESS
DVD SETTINGS
DVD Size: 3812/4435 MB (86%)
DVD Output Setup: DVD Folder
Save Log file: Yes
Info: MPEG-2 Video - 4179 kbps - 720x576 - DAR 1.778 - 25 fps - TFF - 1:58:49 hours - 178246 frames
Subs:
[MediaInfoLib - v0.7.8]
AVISYNTH SCRIPT
Target Video FileSize: 3552 MB
FFmpeg Parameters: -i "C:\Documents and Settings\Administrator\My Documents\My Videos\Saints v Scarlets 1 Nov 08.mpg" -vcodec copy "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.m2v"
<07-01-2009 09:50:28>
Created File: C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.m2v (3621.7 MB)
START TRANSCODING OPERATIONS
ReJig Parameters: -size 3551 -o "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.ReJig.m2v" -i "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.m2v" -auto -close -quiet
<07-01-2009 09:54:47>
END TRANSCODING OPERATIONS
Transcoding excuted on File: C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.m2v (3550.7 MB)
<07-01-2009 09:54:48>
OUTPUT VIDEO INFO:
Filename: Saints v Scarlets 1 Nov 08_2_Title_01
Filesize: 3723230863 Byte
Format: MPEG Video
Time: 0 seconds
AvgBitRate: 15900
Resolution: 720x576
Aspect Ratio: 1.778
FPS: 25.000
Interlacement: TFF
Frames: 12
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Title_01.avs" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Title_01.wav"
Aften (AC3) Parameters: -b 192 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Title_01.wav" "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.ac3"
<07-01-2009 10:12:05>
Created File: C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.ac3 (154.6 MB)
<07-01-2009 10:12:12>
BatchMux Parameters: -arglist "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_BatchMux.ini"
BatchMux ini file:
-d "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2\VIDEO_TS"
-mxp "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_MuxMan.mxp"
-prio LOW
-v "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.m2v"
-vidmode LB
-a1 "C:\Documents and Settings\Administrator\My Documents\Saints v Scarlets 1 Nov 08_2_Title_01.ac3"
-a1lang en
-cellfr "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Title_01_MuxMan.txt"
-progfr "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Title_01_MuxMan.txt"
-chapfr "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Title_01_MuxMan.txt"
-SEG2v "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Menu.bmp"
-SEG2vidmode LB
-SEG2s1 "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Menu.sst"
-SEG2hlmnu "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_Buttons.mnu"
-hcn "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Saints v Scarlets 1 Nov 08_2_BatchMux.hcn"
<07-01-2009 10:29:33>
AVSTODVD LOG FILE <C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\MY DOCUMENTS\SAINTS V SCARLETS 1 NOV 08_2.LOG>
BATCHMUX LOG FILE <C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\MY DOCUMENTS\SAINTS V SCARLETS 1 NOV 08_2_BATCHMUX.LOG>
<07-01-2009 10:29:35>
Log file created by AVStoDVD Release 2.1.3 Alpha build 090102
You can try following things (in order):
1. Do not create chapters: go to 'Settings'/'Authoring Burning'/'Chapters Interval' and select 999 minutes.
2. Re-encode video: go to 'Settings'/'Audio Video' and toggle off 'Keep/Transcode DVD compliant video'
3. Send me by email (avstodvd@gmail.com) a small portion (1000 frames should be enough) of that critical mpeg file.
Let me know
MrC -
A suggestion, not related to the current authoring issue. I have seen from the log file that your input mpg file has a DVD compliant mp2 audio stream. You can tell AVStoDVD to use mp2 stream and keep it without converting to ac3: go to 'Settings'/'Audio Video'/'Default Audio Format' and change from AC3 to MP2.
Bye -
Option 1 worked perfectly (well, the DVD burned, haven't watched it yet) - thanks for all your helpOriginally Posted by _MrC_
Do you want me to send you a portion of the MPEG file? If so, how do I go about isolating the small portion of it?
Thanks again,
Al. -
I forgot the logs.
<18/02/2010 22:33:00>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 5
DVD Size: 4649/4650 MB (100%)
DVD Label: DVD
DVD Menu: Motion Menu
Output Folder: Q:\dvd_pronto
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 0
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 256
Keep DVD Compliat Audio: 0
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: PT - Portuguese
Chapthers Interval: 5
Use Source Chapters: 0
DVD Burning Drive: N: HL-DT-ST DVDRAM GSA-4167B DL13
DVD Burning Speed: 8x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Video: M:\SG1\Stargate SG-1 [1x09] Thor's Hammer.avi
Info: DivX 3 Low - 909 kbps - 640x360 - DAR 1,778 - 23,976 fps (CFR) - - 44:12 minutes - 63595 frames
Audio: M:\SG1\Stargate SG-1 [1x09] Thor's Hammer.avi
Info: AC3 - 192 kbps - CBR - 48000Hz - 2ch - 44:12 minutes
Subs: M:\SG1\Stargate SG-1 [1x09] Thor's Hammer.srt
[MediaInfoLib - v0.7.26]
AVISYNTH SCRIPT
Import("H:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("M:\SG1\Stargate SG-1 [1x09] Thor's Hammer.avi", CacheFolder = "Q:\dvd_temp")
Audio = A2DAudioSource("M:\SG1\Stargate SG-1 [1x09] Thor's Hammer.avi", CacheFolder = "Q:\dvd_temp")
#Using DGPulldown to upsize FPS
Video = Video.Lanczos4Resize(720,480)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 802,1 MB
HCenc Parameters: -ini "Q:\dvd_temp\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.HCenc.ini"
HCenc ini file:
*INFILE Q:\dvd_temp\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.avs
*AVSRELOAD
*OUTFILE Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.m2v
*LOGFILE Q:\dvd_temp\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.HCenc.log
*MAXBITRATE 9000
*BITRATE 2537
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<18/02/2010 22:44:17>
A2DVideoSource: AVISource
Created File: Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.m2v (802,6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2554 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 44:09 minutes - 63531 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<18/02/2010 22:44:42>
END PULLDOWN OPERATIONS
DGPulldown executed on File: Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.m2v (802,6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2552 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive (2:3 Pulldown) - 44:12 minutes - 63595 frames
Wavi+Aften Parameters: "Q:\dvd_temp\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.avs" - | "H:\Program Files\AVStoDVD\Aften\aften.exe" -b 256 -pad 0 -dynrng 5 -bwfilter 0 - "Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.ac3"
<18/02/2010 22:45:04>
A2DAudioSource: DirectShowSource
Created File: Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.ac3 (80,9 MB)
OUTPUT AUDIO INFO: AC3 - 256 kbps - CBR - 48000Hz - 2ch - 44:12 minutes
START SUBS ENCODING OPERATIONS
SubtitleCreator Parameters: "Q:\dvd_temp\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.srt" -p4 -i"H:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IFO"
<18/02/2010 22:45:09>
END SUBS ENCODING OPERATIONS
Created File: Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.sup (1,2 MB)
TITLE 2 SOURCE FILES
Video: M:\SG1\Stargate SG-1 [1x10] The Torment Of Tantalus.avi
Audio: M:\SG1\Stargate SG-1 [1x10] The Torment Of Tantalus.avi
Info: AC3 - 192 kbps - CBR - 48000Hz - 2ch - 44:11 minutes
Subs: M:\SG1\Stargate SG-1 [1x10] The Torment Of Tantalus.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("M:\SG1\Stargate SG-1 [1x10] The Torment Of Tantalus.avi", CacheFolder = "Q:\dvd_temp")
Audio = A2DAudioSource("M:\SG1\Stargate SG-1 [1x10] The Torment Of Tantalus.avi", CacheFolder = "Q:\dvd_temp")
HCenc Parameters: -ini "Q:\dvd_temp\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.HCenc.ini"
HCenc ini file:
*INFILE Q:\dvd_temp\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.avs
*AVSRELOAD
*OUTFILE Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.m2v
*LOGFILE Q:\dvd_temp\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.HCenc.log
*MAXBITRATE 9000
*BITRATE 2537
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<18/02/2010 22:56:47>
Created File: Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.m2v (802,6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2555 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 44:09 minutes - 63531 frames
DGPulldown Parameters: "Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<18/02/2010 22:57:13>
DGPulldown executed on File: Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.m2v (802,6 MB)
Wavi+Aften Parameters: "Q:\dvd_temp\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.avs" - | "H:\Program Files\AVStoDVD\Aften\aften.exe" -b 256 -pad 0 -dynrng 5 -bwfilter 0 - "Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.ac3"
<18/02/2010 22:57:36>
Created File: Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.ac3 (80,9 MB)
SubtitleCreator Parameters: "Q:\dvd_temp\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.srt" -p4 -i"H:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<18/02/2010 22:57:41>
Created File: Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.sup (1,3 MB)
TITLE 3 SOURCE FILES
Video: M:\SG1\Stargate SG-1 [1x11] Bloodlines.avi
Info: DivX 3 Low - 906 kbps - 640x360 - DAR 1,778 - 23,976 fps (CFR) - - 44:12 minutes - 63597 frames
Audio: M:\SG1\Stargate SG-1 [1x11] Bloodlines.avi
Subs: M:\SG1\Stargate SG-1 [1x11] Bloodlines.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("M:\SG1\Stargate SG-1 [1x11] Bloodlines.avi", CacheFolder = "Q:\dvd_temp")
Audio = A2DAudioSource("M:\SG1\Stargate SG-1 [1x11] Bloodlines.avi", CacheFolder = "Q:\dvd_temp")
Target Video FileSize: 802,4 MB
HCenc Parameters: -ini "Q:\dvd_temp\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.HCenc.ini"
HCenc ini file:
*INFILE Q:\dvd_temp\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.avs
*AVSRELOAD
*OUTFILE Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.m2v
*LOGFILE Q:\dvd_temp\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.HCenc.log
*MAXBITRATE 9000
*BITRATE 2537
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<18/02/2010 23:09:33>
Created File: Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.m2v (802,6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2554 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 44:09 minutes - 63533 frames
DGPulldown Parameters: "Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<18/02/2010 23:10:00>
DGPulldown executed on File: Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.m2v (802,6 MB)
Wavi+Aften Parameters: "Q:\dvd_temp\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.avs" - | "H:\Program Files\AVStoDVD\Aften\aften.exe" -b 256 -pad 0 -dynrng 5 -bwfilter 0 - "Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.ac3"
<18/02/2010 23:10:22>
Created File: Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.ac3 (80,9 MB)
SubtitleCreator Parameters: "Q:\dvd_temp\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.srt" -p4 -i"H:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<18/02/2010 23:10:26>
Created File: Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.sup (1,1 MB)
TITLE 4 SOURCE FILES
Video: M:\SG1\Stargate SG-1 [1x12] Fire And Water.avi
Info: DivX 3 Low - 910 kbps - 640x360 - DAR 1,778 - 29,97 fps (CFR) - - 44:12 minutes - 79495 frames
Audio: M:\SG1\Stargate SG-1 [1x12] Fire And Water.avi
Subs: M:\SG1\Stargate SG-1 [1x12] Fire And Water.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("M:\SG1\Stargate SG-1 [1x12] Fire And Water.avi", CacheFolder = "Q:\dvd_temp")
Audio = A2DAudioSource("M:\SG1\Stargate SG-1 [1x12] Fire And Water.avi", CacheFolder = "Q:\dvd_temp")
HCenc Parameters: -ini "Q:\dvd_temp\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.HCenc.ini"
HCenc ini file:
*INFILE Q:\dvd_temp\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.avs
*AVSRELOAD
*OUTFILE Q:\dvd_pronto\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.m2v
*LOGFILE Q:\dvd_temp\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.HCenc.log
*MAXBITRATE 9000
*BITRATE 2537
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<18/02/2010 23:24:32>
Created File: Q:\dvd_pronto\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.m2v (802,6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2555 kbps - 720x480 - DAR 1,778 - 29,97 fps (CFR) - Progressive - 44:09 minutes - 79416 frames
Wavi+Aften Parameters: "Q:\dvd_temp\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.avs" - | "H:\Program Files\AVStoDVD\Aften\aften.exe" -b 256 -pad 0 -dynrng 5 -bwfilter 0 - "Q:\dvd_pronto\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.ac3"
<18/02/2010 23:24:54>
Created File: Q:\dvd_pronto\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.ac3 (80,9 MB)
SubtitleCreator Parameters: "Q:\dvd_temp\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.srt" -p4 -i"H:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<18/02/2010 23:24:59>
Created File: Q:\dvd_pronto\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.sup (1,1 MB)
TITLE 5 SOURCE FILES
Video: M:\SG1\Stargate SG-1 [1x13] Hathor.avi
Audio: M:\SG1\Stargate SG-1 [1x13] Hathor.avi
Subs: M:\SG1\Stargate SG-1 [1x13] Hathor.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("M:\SG1\Stargate SG-1 [1x13] Hathor.avi", CacheFolder = "Q:\dvd_temp")
Audio = A2DAudioSource("M:\SG1\Stargate SG-1 [1x13] Hathor.avi", CacheFolder = "Q:\dvd_temp")
HCenc Parameters: -ini "Q:\dvd_temp\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.HCenc.ini"
HCenc ini file:
*INFILE Q:\dvd_temp\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.avs
*AVSRELOAD
*OUTFILE Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.m2v
*LOGFILE Q:\dvd_temp\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.HCenc.log
*MAXBITRATE 9000
*BITRATE 2537
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<18/02/2010 23:36:27>
Created File: Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.m2v (802,6 MB)
DGPulldown Parameters: "Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<18/02/2010 23:36:52>
DGPulldown executed on File: Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.m2v (802,6 MB)
Wavi+Aften Parameters: "Q:\dvd_temp\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.avs" - | "H:\Program Files\AVStoDVD\Aften\aften.exe" -b 256 -pad 0 -dynrng 5 -bwfilter 0 - "Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.ac3"
<18/02/2010 23:37:14>
Created File: Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.ac3 (80,9 MB)
<18/02/2010 23:37:15>
SubtitleCreator Parameters: "Q:\dvd_temp\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.srt" -p4 -i"H:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<18/02/2010 23:37:20>
Created File: Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.sup (1,3 MB)
START DVD MENU BUILDING OPERATIONS
DVD Menu settings: Style 1, DAR 0, Titles Format 1, Video BitRate 6000, Menu Pages 1, Menu Titles 5
<18/02/2010 23:47:09>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): Q:\dvd_temp\DVD_0_MenuPage1.m2v (0 MB)
Created File: Q:\dvd_temp\DVD_0_Menu.ac3 (0,6 MB)
BatchMux Parameters: -arglist "Q:\dvd_temp\DVD_0_BatchMux.ini"
BatchMux ini file:
-d "Q:\dvd_pronto\DVD_0\VIDEO_TS"
-mxp "Q:\dvd_temp\DVD_0_MuxMan.mxp"
-l "Q:\dvd_temp\DVD_0_MuxMan.log"
-muxman "H:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.m2v"
-vidmode LB
-a1 "Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.ac3"
-a1lang en
-s1 "Q:\dvd_pronto\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer.sup"
-s1lang pt
-cellfr "Q:\dvd_temp\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer_MuxMan.txt"
-progfr "Q:\dvd_temp\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer_MuxMan.txt"
-chapfr "Q:\dvd_temp\DVD_0_Title_01_Stargate SG-1 [1x09] Thor's Hammer_MuxMan.txt"
-SEG2v "Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.m2v"
-SEG2vidmode LB
-SEG2a1 "Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.ac3"
-SEG2a1lang en
-SEG2s1 "Q:\dvd_pronto\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus.sup"
-SEG2s1lang pt
-SEG2cellfr "Q:\dvd_temp\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus_MuxMan.txt"
-SEG2progfr "Q:\dvd_temp\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus_MuxMan.txt"
-SEG2chapfr "Q:\dvd_temp\DVD_0_Title_02_Stargate SG-1 [1x10] The Torment Of Tantalus_MuxMan.txt"
-SEG3v "Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.m2v"
-SEG3vidmode LB
-SEG3a1 "Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.ac3"
-SEG3a1lang en
-SEG3s1 "Q:\dvd_pronto\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines.sup"
-SEG3s1lang pt
-SEG3cellfr "Q:\dvd_temp\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines_MuxMan.txt"
-SEG3progfr "Q:\dvd_temp\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines_MuxMan.txt"
-SEG3chapfr "Q:\dvd_temp\DVD_0_Title_03_Stargate SG-1 [1x11] Bloodlines_MuxMan.txt"
-SEG4v "Q:\dvd_pronto\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.m2v"
-SEG4vidmode LB
-SEG4a1 "Q:\dvd_pronto\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.ac3"
-SEG4a1lang en
-SEG4s1 "Q:\dvd_pronto\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water.sup"
-SEG4s1lang pt
-SEG4cellfr "Q:\dvd_temp\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water_MuxMan.txt"
-SEG4progfr "Q:\dvd_temp\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water_MuxMan.txt"
-SEG4chapfr "Q:\dvd_temp\DVD_0_Title_04_Stargate SG-1 [1x12] Fire And Water_MuxMan.txt"
-SEG5v "Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.m2v"
-SEG5vidmode LB
-SEG5a1 "Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.ac3"
-SEG5a1lang en
-SEG5s1 "Q:\dvd_pronto\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor.sup"
-SEG5s1lang pt
-SEG5cellfr "Q:\dvd_temp\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor_MuxMan.txt"
-SEG5progfr "Q:\dvd_temp\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor_MuxMan.txt"
-SEG5chapfr "Q:\dvd_temp\DVD_0_Title_05_Stargate SG-1 [1x13] Hathor_MuxMan.txt"
-SEG6v "Q:\dvd_temp\DVD_0_MenuPage1.m2v"
-SEG6vidmode 4:3
-SEG6a1 "Q:\dvd_temp\DVD_0_Menu.ac3"
-SEG6s1 "Q:\dvd_temp\DVD_0_Menu.sst"
-SEG6s1dmode LB
-SEG6hlmnu "Q:\dvd_temp\DVD_0_MenuPage1_Buttons.mnu"
-SEG6hlcsm "H:\Program Files\AVStoDVD\Menu\Highlight_Scheme.csm"
-hcn "Q:\dvd_temp\DVD_0_BatchMux.hcn"
<18/02/2010 23:48:18>
PROCESS ABORTED DURING DVD AUTHORING OPERATIONS!
AVSTODVD LOG FILE <Q:\DVD_PRONTO\DVD_0.LOG>
BATCHMUX LOG FILE <Q:\DVD_PRONTO\DVD_0_BATCHMUX.LOG>
<18/02/2010 23:48:21>
Log file created by AVStoDVD Release 2.2.6
<>Last edited by trabanom; 19th Feb 2010 at 16:39.
Ok, i'll try this at home but my home language uses ",". Is there a work around if this is the problem?
I was also getting the error msj "script error: the named argument "start" was passed more than once to imagesource" and I arrived here thanks to Google.
After reading the post from _MrC_
I did it and it solved the inconvenience.It could be a decimal separator issue: go to Windows International settings and change from "," to "."
Thanks a lot! -
yeah--- am back agian..
and i have a big problem when i Try to use AVStoDVD white thw serie Contiuum..
I get this
Proscess abortede during Title 1 AUDIO (Track 2) encoding operations
and I have read all the threats in here for the problem... så i Dont get it.. and I have using popcorn program.. to make AC3 track.. -
Log file 1
DVD Burning Speed: 4x
Save Log file: 1
Save General Settings: 0
<14-01-2013 09:35:01>
Video: D:\Downloads\Continuum.S01.Custom.DKsubs.COMPLETE. 720p.HDTV.x264-NGS\Continuum eps 1_AC3.mkv
Info: AVC - 4000 kbps - 1280x720 - DAR 1,778 - 23,976 fps (VFR) - Progressive - 43:50 minutes - 63067 frames
Audio 1: D:\Downloads\Continuum.S01.Custom.DKsubs.COMPLETE. 720p.HDTV.x264-NGS\Continuum eps 1_AC3.mkv
Info: DTS - 768 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 43:50 minutes (-83 ms delay) - Internal (Track 2)
Audio 2: D:\Downloads\Continuum.S01.Custom.DKsubs.COMPLETE. 720p.HDTV.x264-NGS\Continuum eps 1_AC3.mkv
Info: AC3 - 640 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 43:50 minutes (-83 ms delay) - Internal (Track 0)
Subs 1: D:\Downloads\Continuum.S01.Custom.DKsubs.COMPLETE. 720p.HDTV.x264-NGS\Continuum eps 1_AC3_DA.srt
[MediaInfoLib - v0.7.59]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\ffms2.dll")
LoadPlugin("C:\Program Files (x86)\AVStoDVD\VobSub\VSFilter.dll")
Video = A2DVideoSource("D:\Downloads\Continuum.S01.Custom. DKsubs.COMPLETE.720p.HDTV.x264-NGS\Continuum eps 1_AC3.mkv", CacheFolder="C:\Users\John\AppData\Local\Temp", FrameRate=23.976, VFR=true)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
# Forced 'FFAudioSource' to extract secondary Audio Tracks
Audio = FFAudioSource("D:\Downloads\Continuum.S01.Custom.D Ksubs.COMPLETE.720p.HDTV.x264-NGS\Continuum eps 1_AC3.mkv", track=3, cachefile="C:\Users\John\AppData\Local\Temp\A2DFFA _" + String(Rand()) + ".cache")
Video = Video.ConvertToYV12()
Video = Video.ConvertFPS("pal_video")
Video = Video.Spline16Resize(720,576)
Video = Video.TextSub("D:\Downloads\Continuum.S01.Custom.D Ksubs.COMPLETE.720p.HDTV.x264-NGS\Continuum eps 1_AC3_DA.srt")
Audio = Audio.DelayAudio(-0.083)
Target Video FileSize: 1171,9 MB
HCenc Parameters: -ini "C:\Users\John\AppData\Local\Temp\DVD_1_Title_01_C ontinuum eps 1_AC3.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\John\AppData\Local\Temp\DVD_1_Title_01_Co ntinuum eps 1_AC3_1.avs
*AVSRELOAD
*OUTFILE C:\Users\John\Videos\DVD_1_Title_01_Continuum eps 1_AC3.m2v
*LOGFILE C:\Users\John\AppData\Local\Temp\DVD_1_Title_01_Co ntinuum eps 1_AC3.HCenc.log
*MAXBITRATE 8668
*BITRATE 3738
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 40
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY HIGH
*WAIT 2
<14-01-2013 09:36:47>
CHECK LOG FILE <C:\USERS\JOHN\VIDEOS\DVD_1.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.5.1
log file 2
<14-01-2013 09:44:55>
START PROCESS
PROJECT SETTINGS
DVD Titles number: 3
DVD Size: 4449/4450 MB (100%)
DVD Output Setup: ISO UDF Image
DVD Label: DVD
DVD Menu: Static Menu
Output Folder: C:\Users\John\Videos
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
PREFERENCES
MultiThread: 1
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Level 1: 6500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 3
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliant Audio: 0
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): DA - Danish
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Arial 20pt (255,255,255)
Chapters Interval: 10
DVD Burning Drive: E: ASUS DRW-24B5ST 1.00
Save Log file: 1
Info: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 43:50 minutes (-83 ms delay) - Internal (Track 1)
AVISYNTH SCRIPT
Audio = A2DAudioSource("D:\Downloads\Continuum.S01.Custom. DKsubs.COMPLETE.720p.HDTV.x264-NGS\Continuum eps 1_AC3.mkv", CacheFolder="C:\Users\John\AppData\Local\Temp")
there are the log files...
sorru for the delay -
The log files are incomplete and, at least for project 1, the abort is not during audio encoding (Track 2), as stated before.
By the way, I can suggest some troubleshooting that MAY suit your needs:
Help/FAQ/General/Q1.5
Help/FAQ/Video/Q3.1
Help/FAQ/Audio/Q4.5
In addition I suggest you to install the latest AVStoDVD 2.6.0 Alpha, which contains several improvements.
Bye -
@Soixante
have you read the software requirements in Readme_NoInstall.txt file?
@Denmark
done what? Have you looked at the FAQ entries? Have you installed and checked all that is suggested in the FAQs? If yes, have you tried again to run the project?
Bye -
MAYBE THIS WILL HELP... maybe it won't
i spent the last two days fighting an audio out of sync with authoring with avstodvd
the source files were a high bitrate 6000 + 740*480 mpeg2 with mp2 256k audio
files sizes were 1.7gig and 2.4gig
they played perfect in vlc but audio went rapidly out of sync when authoring a dvd
after numerous trys, what worked
was to load the source into video redo and make a few edits 'cut out some blank space between scene changes' and save the file with an altered file name
load the edited files into avstodvd, run dgindex and author the dvd
this fixed my audio issues
something similar might fix your authoring issues
Hauppauge 2250 Tuner Card Aborts Recordings
By rixware in forum CapturingReplies: 8Last Post: 30th Jul 2012, 12:14 -
Unable to extract audio - BD-Rebuilder aborts
By mobie29 in forum Blu-ray RippingReplies: 4Last Post: 7th Apr 2011, 09:19 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 07:29 -
Capture aborts when media format changes
By Undead Sega in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 22nd May 2008, 17:09 -
Nero 7 Ultra Edition Aborts DVD to Burn
By uLmighty in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2007, 02:02
