VideoHelp.com Forum
    At loading, I have .net framework 1.1, 2.0 sp2, 3.0 sp2 and 3.5 sp1.
    old version (2.0) worked good for me but since my hard drive got a bad status and i had to replace it, new version don't work.
    Any idea?
    Version: SVCD2DVD 2.5
    Build: 2.5.5020.0
    Type: System.NotSupportedException
    Source: CodeLock
    Message: Variable uses an Automation type not supported in Visual Basic
    InnerException:
    StackTrace: at CodeLock._Secure.Initialize(String protected_file)
    at AxCodeLock.AxSecure.Initialize(String protected_file)
    at x3284ccece41ee22b.x2f5590cb48bb0c53.x83f20715bdcc4 873(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
    at System.Windows.Forms.Control.set_Visible(Boolean value)
    at System.Windows.Forms.Application.ThreadContext.Run MessageLoopInner(Int32 reason, ApplicationContext context)
    at System.Windows.Forms.Application.ThreadContext.Run MessageLoop(Int32 reason, ApplicationContext context)
    at System.Windows.Forms.Application.Run(Form mainForm)
    at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426)
    ok I managed to get it working by uninstalling and reinstalling .net framework.
    thanks
  3. Member ChrissyBoy's Avatar
    Cool
  1. iTunes + Windows XP 64 bits, how?
    By NormaJ in forum Software Playing
    Last Post: 29th Dec 2010, 22:14
  2. Vista 64 bits with 32 bits programs
    By skaleton in forum Computer
    Last Post: 15th May 2009, 11:41
  3. Fatal Error on Startup SVCD2DVD 2.5 (CRASH)
    By jenevans33 in forum SVCD2DVD & VOB2MPG
    Last Post: 16th Mar 2008, 10:06
  4. Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
    By maxtrack in forum Newbie / General discussions
    Last Post: 11th Sep 2007, 00:38
  5. SVCD2DVD Crash with subtitle
    By half-life in forum SVCD2DVD & VOB2MPG
    Last Post: 2nd Jul 2007, 10:36
