Matshita slot loaders have difficulty in actually burning DL media, they often just won't do it despite the specs saying they can. I have two UJ-875s that definitely won't. Make sure you are using Verbatim DL media, no other DL works reliably, especially on the more picky burners. If your UJ-850 rejects even Verbatim DL, but works in every other way, its probably normal. Buy a cheap external burner for DL, if you absolutely have to have DL capability.
Ok thanks, because I have tried Verbatim and that doesn't work. Can u recommend any specific external burner that can burn DL?
The Pioneers are usually pretty good. The DVR-X152 is available new from the usual vendors like NewEgg for about $90. Or, you could check eBay and surplus dealers for the earlier DVR-X122 which I've seen as low as $29.95 if you'll take "refurbished" (i.e. some idiot bought it and couldn't find the USB socket on their laptop so they returned it).
VAIO E series Matshita BD-CMB UJ141AS
By difoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Mar 2010, 18:56 -
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 11:50 -
DVD burning problems
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 00:11 -
Help with Matshita Drive/Adobe Encore V2
By bailout in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Aug 2007, 13:16 -
matshita dvd ram uj 840s
By skaterboii in forum DVD RippingReplies: 3Last Post: 16th Jul 2007, 04:11
