For some reason when encoding region-free DVDs from a VIDEO_TS folder on my hard disk into xvid (avi mencoder, customised preset), the progress percentages shown in the ffmpegX Progress window are much lower than reality
i.e. I set off a conversion and the progress does go up, but very slowly, to about 20% or so at most, then jumps to 100% completion and the video is indeed properly complete.
Is this a bug or a known issue?
Tom
There are some known inaccuracies in the progress percentage, but I do not recall the behavior that you describe.
Given that this is reproducable, should I file a bug report, and if so, how?
There is a "ffmpegX bugs and suggestions" forum here, where it could be posted. Perhaps you could use the "Report this post" link (in the first message) to ask a moderator to move this topic there.
Progress issue
By djw66 in forum ffmpegX general discussionReplies: 2Last Post: 30th Jun 2011, 16:46 -
HELP!!! ffmpegx progress zero kb
By smjsinclair in forum ffmpegX general discussionReplies: 6Last Post: 9th Aug 2010, 18:06 -
percentage of hard drives fail
By MJA in forum ComputerReplies: 29Last Post: 4th May 2009, 11:44 -
Where is Progress.app
By Roebi in forum ffmpegX general discussionReplies: 6Last Post: 18th Jul 2008, 19:32 -
Percentage (%) going over 100 %
By enzofsilva in forum ffmpegX general discussionReplies: 2Last Post: 23rd May 2007, 22:26
