I'd like to view Neflix movies from my computer (all those "instant" ones you get with membership) and other stuff on my TV. Problem is I can't figure out how to get the signal there. Well I know I don't have an s-video out port on the computer though the TV has s-video in. It seems strange to me that although I have a Gateway DX310X with XP Media Center OS there seems to be no TV out option on the system. Am I just missing it? I also have a Hauppage Win TV PVR but this has no "out" option either. I figure I need to get another graphics card with s-video out for the PCI Express 16 slot that is open. Is this the direction I should take or are there other options? I"m not interested in the Netflix Roku..I believe this limits me to Netflix and there may be other things I want to view on the TV from the PC. Thanks in advance for whatever suggestions you have. Oh yes..if the new card is the option can you recommend one? Betty
Thread: Need some general info...
If your TV accepts VGA, DVI, or HDMI those are your best options (pretty much limited to HDTVs).
Some computers come with 7-pin video outputs instead of the usual 4 pin s-video plug. An s-video cable can often be plugged into this connector because s-video is provided on the 4 pins that match the cable. Or the manufacturer may supply an adapter.
Otherwise, a new graphics card with s-video out is probably your best bet. You can get VGA to s-video scan converters but quality ones cost more than a decent graphics card.
DVP 642 firmware changelog and general info
By edplayer in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Dec 2004, 08:30 -
Looking 4 general info on M2V files
By obas in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2003, 16:32 -
General info needed Dvd rip - burn with a DVD writer?
By beemie in forum DVD RippingReplies: 3Last Post: 14th Nov 2001, 19:37 -
What tool for info info on a mpeg2 file?? (Cutting prob. i
By el-Dia in forum EditingReplies: 0Last Post: 20th Oct 2001, 02:14 -
General Help..
By sixdsix in forum Video ConversionReplies: 18Last Post: 30th Jul 2001, 01:55
