Hi!
I have been searching for an easy to use conversion of .264 (demuxed m2ts file) to a divx file.
The only program I found so far which can do it, is Super, but the conversion has leaded me to a timing difference of two hours making it out of sync to the audio.
Any other tools or any help?
Thank you guys!
Thread: .264->DivX
Why demux ? Xvid4PSP can handle .m2ts files.
Thanks. Looks like a great tool. Unfortuatly it gives me the same gap of two seconds and therefore audio/video are out of sync.
Look under the audio - editng options and you can set an offset to compensate
I don't know about your audio source, but the thinking should be, either you set this delay through the A) editing of the audio stream, or B) at the container level.
A) Depending on whether the delay is -ve, or +ve, just cut 2 seconds, or add 2 seconds of a blank chunk, using an audio editor that supports the format, and remux.
B) Set delays in audio when remuxing into the container, such as .avi. DivXMuxGUI does this for you (and I think it's at the container level).Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
DivX vs. H.264. vs. Divx HD: What best for playback on Philips BDP5320 ???
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 26Last Post: 21st Sep 2011, 04:50 -
H.264 ts to Divx(XVID)
By olegy in forum Video ConversionReplies: 11Last Post: 4th May 2010, 11:29 -
h.264 to divx
By degarb in forum Video ConversionReplies: 12Last Post: 4th May 2010, 11:27 -
H.264 - Divx..... problem !!!
By tjolle62 in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 16:45 -
H.264 Versus DivX
By shapper in forum Newbie / General discussionsReplies: 1Last Post: 31st May 2008, 23:01
