I've never been so confused on how to accomplish a technical task. I can't even find an off the shelf application (like Roxio) that states that is supports the Canon DC230 video camera or works in Windows XP. I don't even know if Roxio is a good product. Help!!!!!!
what's a canon dc30? it doesn't seem to be a canon product model number.
Canon DC230. Sorry.
first, always make sure your dvd is finalized before trying to use it. since it's already in dvd format vobs (mpeg-2), a good choice would be womble's video wizard dvd as it will edit without re-encoding. if you want to make simple cuts the free dvdshrink has a re-author mode that will cut out pieces or join them. almost all other editors will work with mpeg-2 but there will be some loss of quality with every re-encode it goes through. before burning you need an authoring program to take the mpeg-2 and convert it to dvd spec files. then the files can be burned to dvd with the freeware program imgburn.
Best IQ possible for standard DVD disc from AVCDH Canon camera source
By littlebob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 14:04 -
Canon DC230 New Ticking Sound On Playback
By cool4cats in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 7th Jan 2012, 07:23 -
MVI from Canon camera file to MPEG2 dvd,
By harrisonford in forum DVD RippingReplies: 3Last Post: 9th Sep 2011, 23:50 -
HD video on Canon t1i - camera turned off before file "closure"
By boommoob in forum MacReplies: 1Last Post: 4th Oct 2009, 11:59 -
Anyone sucessfully played .avi files from a Canon camera on a DVD player?
By micallen in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Nov 2007, 14:51
Statistics
Newest guides
Latest tool updates
New media comments
