How can I split it so it fits on two dvd's? I'm not trying to do anything fancy with menu's etc, just want to fit it on two discs to back up.
Results 1 to 22 of 22
Use dvd shrink in the reauthoring mode. http://www.dvdshrink.info/reauthor_intermediate.php
Wow that was a great walk thru, and looks like a great option. Only problem is DVD shriek appears to not like the type of file it is.
I tried to drag it in and it said "invalid file name" -
Thats weird under type of file it just says "movie clip" I thought it would say something like "mpeg, jepg, avi, wma" under properties. Movie clip isn't really an extention, that i know of
Originally Posted by minidv2dvd
and the file location line ends with .mpg -
So what exactly is mpg-ps? I've never heard of it before. I made these files with a tv capture card
The guide that Baldrick recommended is very good. Can it be saved for offline viewing?
Yes. Simply use Flashgot or any other stream downloader to get the file. Or you can simply right-click and save as, then open in your browser.
Originally Posted by Supreme2k
I'm also trying to save youtube type videos, was this a good software he mentioned? what is the best (free) one? -
And I don't need it to be the same type of file when it's done. Is there a better format I should copy them as? All I want to do is put the cropped file on a dvd then be able to watch them either in a dvd player or on the computer with any program I have. -
no one got banned, that is his avatar. private joke i imagine.
you can convert to any format you want but everytime you re-encode something to another format it will lose quality.
since mpg is already compressed the file size decrease won't be large unless you reduce the bitrate significantly and really lose a lot of quality in the process. -
Also any idea what the priority option is for? default is low -
i don't think it will predict filesize.
priority is the setting for cpu usage. -
Oy, why would a 4.58gb file not fit on a 4.7gb dvd??!!! Looks like I have to cut it again
actual dvdr size is 4.365GB - same marketing speak as hard drive sizes. it's the bits vs. bytes thing.
So what can i expect the mpeg-ps to play on/with? Even the burn dvd shows the icon of an un reconized file format, I have to select windows media each time and thats all it works with.
How to capture a photo off a dvd or a video file?
By scustalow in forum Newbie / General discussionsReplies: 132Last Post: 8th Jul 2017, 12:12 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Smaller file size after Video Capture (help)
By convoy71 in forum CapturingReplies: 4Last Post: 4th Apr 2009, 17:05 -
How to capture 4 video streams and combine into a 4-window single file ?
By halfwalker in forum CapturingReplies: 5Last Post: 22nd Jul 2007, 22:08
