Hi All,
I just recently purchased a Intel Core2 QUAD 6600 3gig system, and would now like to add a quality DVD SATA Burner, but not sure which to buy?
I currenlty have a IDE Plextor PX712A, and PX716A that has served me well on my old server. I would like to stay with plextor but open to suggestions for my type of system. When I look at plextor's website, and pioneer's website, I can't tell the difference between each DVD burner they offer. I also don't know, if I can change the BIT TYPE SETTING, on these new drives.
1. Must be able to change Bit Type Setting on DL disk when using ImgBurn.
2. Not sure if LightScribe Direct Disc Labeling will work on Verbatim Inkjet Printable DVD+R DL
Thanks.
Results 1 to 21 of 21
My first suggestion would be to get the PIONEER 216 Sata dvd burner but you'll have to use MEDIA CODE SPEED EDIT to enable bitsetting.
PIONEER, $29.99
http://www.newegg.com/Product/Produc...82E16827129032
Or get a LG or SAMSUNG SATA dvd burner.
LG, $22.99 FREE SHIPPING
http://www.newegg.com/Product/Produc...82E16827136152
SAMSUNG, $24.99 FREE SHIPPING
http://www.newegg.com/Product/Produc...82E16827151171
Originally Posted by budz
When using the MediaCodeSpeedEdit, is the change made directly within the burner itself, or can I change it using ImgBurn?
Thanks!
LightScribe will only work with LightScribe compatible discs.Originally Posted by mlong30
I used Light Scribe until I noticed the label flakes off over time. Not so good.
I've not heard of this before now.Originally Posted by dnathanAnswers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
i've got some a couple years old. never had any labels flake off but they do wear off pretty quickly if used in fabric cd holders.Originally Posted by dnathan
Those dirty rats!!!!!!!Originally Posted by budz
When did they get them back in ?
Oh well, i already bought one somewhere else
EDIT:
Oh wait.... they don't!!!
Deactivated Item
EDIT AGAIN !!
Now i see, it's a newb digging up an old thread
Originally a member since 2001, LONG LIVE TARAN's!!!
Originally Posted by Noahtuck
edit:
Sorry, I could stop laughing....seems this (old threads) is catching a lot of people off gaurd lately
it would be cool to check the last post's date and, if over 6 months old, display a warning image
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
Originally Posted by stiltman
I just lost my senses because i saw the link Budz linked to for the drive i was looking for but newegg did not have them listed last week, kind of got overly excited until i looked at it
I guess I screwed up! I purchased the Plextor SATA PX880SA, and now I can't set my book type using Img Burn 2.5Originally Posted by budz
Is there a list of SATA drives that have Book Type built in?
Thanks!
Whoas! I only saw this post now on 9/8/09!
Yup, you can booktype with that Plextor drive by using IMGBURN.
On IMGBURN go to TOOLS...then click on DRIVE.....then go to CHANGE BOOKTYPE
then click on the PLEXTOR TAB....then just follow what it says to booktype to DVD-ROM.
This thread is just determined to never die!!Originally Posted by budz
LOL!!
Ya know... i have had many drives that ImgBurn was supposed to be able to set the book type on, yet i have never been able to get it to change the booktype.
I always had to use modded firmware.Originally a member since 2001, LONG LIVE TARAN's!!!
I've never had any problems with using the booktype setting in IMGBURN....But then again I've always checked to see which brands of dvdrw's would be compatible with IMGBURN's booktype setting. And if not then like you I've used modded, but I call it hacked firmware!Originally Posted by Noahtuck
I tried this and it didn't work. It works on my old plextor PX-716A, but not the new one SATA PX880SA.Yup, you can booktype with that Plextor drive by using IMGBURN.
Matt
I'd suggest going to the IMGBURN forum and post your question there. LightningUK may have a answer for you or post it at CDFreaks.com in the PLEXTOR forum.Originally Posted by mlong30
Plextor drives aren't real Plextor drives now.
You might find that you can change the booktype by using the make that goes along with the REAL manufacturer of your Plextor branded drive.
i.e. it might have Plextor written on it but really its a LiteOn / Samsung / Optiarc drive.
Well, hacked, modded, tomato, tomăto :POriginally Posted by budz
I pretty much exclusively use Verbatim so i would hope that media would be comatable with ImgBurn's booktype setting feature.
But i really can't test it now because i am using "altered" firmware :P
I never really looked into it because it was just easier to reflash any of my drives and never have to think about it again.Originally a member since 2001, LONG LIVE TARAN's!!!
Originally Posted by LIGHTNING UK!
I completely forgot that Plextor doesn't manufacture their own drives.
Could someone recommend a good SATA CD/DVD burner?
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Feb 2011, 23:41 -
sata dvd burner in older computer
By victoriabears in forum DVD & Blu-ray WritersReplies: 1Last Post: 1st Apr 2010, 01:28 -
can't burn with sata dvd burner
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 14:53 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 20:15 -
advice on an SATA dvd burner?
By lumis in forum ComputerReplies: 4Last Post: 19th Jun 2007, 04:09
