Hi
I have seen lots of threads and all of them seem to end in misery!!
I have a sont HD camcorder and have installed all the software, i also installed pinnacle 12 and prem cs4 (my software of choice)
I can watch the files in sony AVCHD player and edit them in pinnacle studio 12
BUT when i try to import the m2ts files into premiere i get "File format not supported"
Whats the best way around this, i dont want to have to convert before i import really!!!
Many Thanks
Chris
Results 1 to 12 of 12
Your first mistake was buing an AVCHD camcorder.........now you'll have to deal with it. Lesson 1, always do your homework first.....................
You can try a trial version of Vegas 8, or frameserve via Avisynth and AVSPlugin for Premiere, or use DGAVCDec and convert to a lossless codec like Lagarith.
..........Sorry, you'll get no sympathy from me, I'm a tried a true HDV user all the way.Never argue with an idiot.......he'll only bring you down to his level and beat you with experience.
ok fair enough boy genious!
Is there anyway to import direct into premier, i dont care about your sypathy or your smuggness!
Also some people dont have £2k to spend on a camcorder!
See if this helps:
Check this Video:
http://www.youtube.com/watch?v=OPBILit71Wg
or this one:
http://www.bestechvideos.com/2008/10...th-avchd-video
http://blogs.adobe.com/davtechtable/...avchd_edi.html
i don't have a sony avdhd cam but i've imported the samples i've found online into pp cs4 without any problem. like the one on this page - avc-avchd(sony).m2ts
http://mirror05.x264.nl/CruNcher/?di...ility_problems
Hmm still no joy, everyone seems to be able to import direct into cs4 i get "unknown file format"
should i be installing a codecs or is there a premier cs4 codecx pack on the cd i have not installed or a plugin maybe on the cs4 cd i have not installed because i cant even import avc-avchd(sony).m2ts
I'm guessing there's something missing when you installed CS4. Maybe a checkbox to install additional support files?
it may be the sony avdhd support was added in the dec08 update. see if you have updated pp cs4 to 4.0.1
Correct, downloaded, installedOriginally Posted by minidv2dvd
Worked First time.
Thank You!
Other than that AVCHD works perfect!
you're welcome. and have a good new year!
Hey minidv2dvd can you tell me what you did exactly?
I am having the same problem. If you can tell me asap that will
be hightly appreciated. I have trial version of vegas9 and get unknown file format" when trying to import m2tvs.
Premiere Pro CS4 AVCHD Presets?
By petronas in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2010, 01:59 -
AVCHD thru Premiere CS4 encodes hiccups in audio
By ddane in forum Video ConversionReplies: 5Last Post: 11th Dec 2009, 16:21 -
Premiere CS4 can't import AVCHD
By cheerful in forum EditingReplies: 23Last Post: 9th Sep 2009, 17:34 -
AVCHD and premiere pro cs4 demo!
By crossbrand in forum EditingReplies: 8Last Post: 7th Jul 2009, 12:19 -
Exporting AVCHD from Premiere Pro CS4
By jodal in forum Video ConversionReplies: 14Last Post: 29th May 2009, 07:12
Newest guidesLatest tool updatesNew media commentsRecent DVD HacksSlysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
