HI,
New to the forum.
I am considering purchasing this unit to replace a Lite-On LVW-5115GHC+ which is starting to give me problems. The Lite-On is connected to my HDTV via component cable.
The aspect ratio question I have is:
If I connect the D-R560 to my 16:9 aspect ratio HDTV via HDMI and play one of my DVD movies (upconverted to 720p or 1080p), will it allow me to view the DVD in its original 4:3 aspect ratio, with sidebars? Or, will it force the aspect ratio to be "stretched" to 16:9?
I do not want the image to be "stretched". I want it to be displayed in it's original aspect ratio, as my Lite-On unit currently does.
I ask this because I purchased a Toshiba D-KR10 at Costco a while ago, connected it to my HDTV via HDMI and it "stretched" the 4:3 DVD image to 16:9. I could not figure out how to get it to display in 4:3. I had to return it.
Is this just a nasty by-product of "upconverting" and connecting via HDMI, or am I just missing something?
Thanks.
It is typically a setup issue. The player should be set to output the same AR as your TV (in this case 16:9) and the TV input should be set to normal (ie: not stretch or zoom).
Google is your Friend
Thanks Krispy Kritter. I figured that, but couldn't seem to get it to work on the D-KR10 I got a while back. Not sure why.
BTW, I emailed Toshiba customer service and received a response. Here it is:
_______________________________________________
Dear Peter:
Thanks for writing!
Yes, you will be able to watch the DVD in 4:3 screen size.
For further assistance, please write back or call our Customer Solutions Department at 1-800-631-3811. They are available Mon-Fri, 8AM to 7PM Central time.
Deandre
Toshiba Customer Service
__________________________________________________ ____
Sounds like it will work.
Now I just have to decide between the Toshiba D-R560, which is in my price range (150USD), or one of the following, which are both more expensive: PHILIPS DVDR3506/37 or Panasonic DMR-EZ28K.
Any opinions and/or suggestions would be appreciated.
Thanks.
Confused Newcomer's Questions About Toshiba D-R560.
By Joliebat in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Oct 2008, 20:50 -
Wrong Aspect Ratio on Toshiba 1850 Portable - How To Fix?
By bluehz in forum Video ConversionReplies: 3Last Post: 29th May 2008, 20:26 -
Display aspect ratio V/S pixel aspect ratio question
By perfection in forum Newbie / General discussionsReplies: 0Last Post: 27th Dec 2005, 07:41 -
HELP! problems with my HDTV aspect ratio..Toshiba is no help
By dprocket in forum DVB / HDTVReplies: 1Last Post: 29th Nov 2005, 14:02 -
changing source aspect ratio, aspect ratio and video mode
By jogy1983 in forum Video ConversionReplies: 1Last Post: 20th Dec 2002, 21:54
Statistics
Newest guides
Latest tool updates
New media comments
