VideoHelp.com Forum
    When preparing files with nav packs, SVCD launches two instances of ffmpeg. Which causes severe disk fragmentation (2500 fragments in a 200M file). I think previous versions only launched 1 ffmpeg. Is there a way to limit the number of ffmpeg instances. I tried setting processor affinity to 1 processor, same result.
    SVCD2DVD v2.5.5020.
    Windows Vista Home Premium
    TOSHIBA Satellite A215
    Processor AMD Turion(tm) 64 X2 Mobile Technology TL-60, 2000 Mhz, 2 Core(s), 2 Logical Processor(s)
    Installed Physical Memory (RAM) 2.00 GB
    Total Physical Memory 1.87 GB
    Available Physical Memory 516 MB
    Total Virtual Memory 3.98 GB
    Available Virtual Memory 2.28 GB
    Page File Space 2.17 GB
  2. Member ChrissyBoy's Avatar
    What assets types are you referring to?
    mpg file. Here's the dump from MediaInfo...
    Format : MPEG-2 Program
    Format/Family : MPEG-2
    File size : 135 MiB
    PlayTime : 2mn 6s
    Bit rate : 8919 Kbps
    Video #0
    Codec : MPEG-2 Video
    Codec/Family : MPEG-V
    Codec profile : Main@Main
    Codec settings, Matrix : Standard
    PlayTime : 2mn 6s
    Bit rate mode : CBR
    Bit rate : 7916 Kbps
    Nominal bit rate : 6000 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display Aspect ratio : 16/9
    Frame rate : 29.970 fps
    Standard : NTSC
    Chroma : 4:2:0
    Interlacement : Top Field First
    Audio #0
    Codec : MPEG-1 Audio layer 2
    PlayTime : 2mn 6s
    Bit rate mode : CBR
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48 KHz
    Resolution : 16 bits
    Video0 delay : 126ms
    Menu #0
    Codec : DVD-Video
  1. Replies: 3
    Last Post: 30th Mar 2009, 02:30
  2. Two instances of FFmpeg
    By ism33 in forum SVCD2DVD & VOB2MPG
    Last Post: 3rd Nov 2008, 15:13
  3. Multiple instances of tmpgenc?
    By Bully9 in forum Video Conversion
    Last Post: 25th Aug 2008, 21:14
  4. multiple instances of dshow being activated
    By radman202 in forum Newbie / General discussions
    Last Post: 29th Jan 2008, 09:50
  5. Replies: 12
    Last Post: 19th Jun 2007, 22:26
