VideoHelp.com Forum
    I was wanting to give this app a try, but, when I run it, gives me this error message: Failed to get data for revision. If I accept (only choice), the program will open, and load the file, but every little window will stay gray. No profile, no fps, no frames, nothing at all.
    I have checked the needed software, and this is what is installed on my PC:
    AviSynth 2.5
    ffdshow Milan Cutka 20051109
    Haali Media Splitter 290308
    Net framework 3.0
    What could be the reason for this error message?
    Thanks in advance
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin).
    Try a newer version of ffdshow. 20051109 is very very very old.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    You need Net Framework 2.0. It's not the same a 3.0. Both can be installed. I would go to the RipBot tool page and use the links there to make sure you have the correct software versions. (Just click on the links for each add on tool) Or the program installer should list the required versions. And of course you need ripped files from AnyDVD or similar ripper.
    Just working like a charm. Thank you both very very much.
  1. RipBot Demuxing Error
    By F.Garvin in forum Blu-ray Ripping
    Last Post: 22nd Feb 2011, 18:07
  2. Sudden RipBot error (avisynth error)
    By Charles314 in forum DVD Ripping
    Last Post: 24th Oct 2010, 01:44
  3. Ripbot error
    By Bazza-61 in forum Blu-ray Ripping
    Last Post: 20th Oct 2010, 08:25
  4. RipBot error?
    By David9799 in forum Blu-ray Ripping
    Last Post: 14th Mar 2010, 15:35
  5. RipBot Error - only on one PC !?
    By elJorda in forum Blu-ray Ripping
    Last Post: 25th Feb 2009, 04:33
