Am using The KMPlayer. I've recently upgraded to a 24 inch monitor(1920x1200 resolution), and low quality(non hd) movies and so forth, is starting to look rather ugly when i watch in fullscreen mode. So am wondering if there is anything i can do with the player to enhance the video quality?
Well if the quality ain't there to begin with, probably not. You might get a better looking picture using some kind of 'soften' or 'blur' and you might be able to adjust the standard stuff like brightness, contrast, gamma, etc. But in the end those steps only mask the lack of quality.
Under Video (Advanced) try turning on Post Processing and aWarpSharp to see if it helps, however the bottom line is very succinctly covered in this simple rule : Garbage In, Garbage Out. Your videos are crap (sorry, but they are, in the big picture scheme of things - pun intended) and there is very little you can do in the way of improvement. You may find the issues aren't as obvious if you simply double the playback screen, instead of running it at full screen.
Aside from what's already covered above, you are likely sitting too close to your monitor. At least for video playback in full screen. Viewing distance for watching video/TV is measured in feet. For a 24" screen, about 6-10'. Even HD content will benefit from you backing away from your monitor.
Google is your Friend
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 01:06 -
need tips to improve theora video quality for html 5 video
By rettew in forum Video ConversionReplies: 5Last Post: 23rd Mar 2011, 11:40 -
Whats the best screen recorder software for high quality video?
By peteman in forum Newbie / General discussionsReplies: 8Last Post: 20th Jan 2011, 13:51 -
Video Captured Low in Quality/Resolution
By kakashi123 in forum CapturingReplies: 4Last Post: 10th Jul 2009, 18:36 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video StreamingReplies: 1Last Post: 22nd Feb 2009, 06:56
