    May 2007
    Help. I have a Fujitsu Siemens Monitor for my PC but the brightness color settings and screen alignment aren't correct. I press the buttons on the monitor which can change it all, but I don't know what is the correct brightness etc setting to use. One of the options it gives is 'Recall' but when I select it, the word 'No' appears beside it.
    Does anyone have the manual for this monitor, perhaps it could tell me how to reset the monitor to factory settings. The model number is TE770B
    Thanks in advance if anyone can help me.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    manual: http://www.fujitsu.com/downloads/AU/TE770B_user_manual.pdf
    Visual settings vary from user to user. Depending on your videocard chipset, nVidia for instance, has a calibration assistant.
    Google is your Friend
