Hi All,
I am having a problem getting MPC to play MKV files with the MPC Video Decoder. I have two pc's, and have it working fine on one, but the other will just not play?
I can get MPC to play the file if I use the FFD show filter, or CoreAVC decoder, but I would like to take advantage of the DXVA as I do on my other PC.
The problem is, when I disable and block the other filters and let MPC Video Decoder be the only filter, MPC opens, but the file does not start playing (just sits at 0.00). When I go into the MPC settings play-filters-MPC Video Decoder, I can see the DXVA enabled (as it is on my other PC), but the file will not play.
I know I am missing something really simple, if anyone could point out to me or need more info to solve, let me know, it would be really appreciated!
Thanks,
tiger
Thread: MPC-HC and MKV playback
I don't play many MKV files, but check to see if one of the machines is missing Haali Media Splitter
Thanks,
Halli Media Splitter installed on both, and does activate when the file is loaded into MPC
Try running DXVA Checker:
http://forum.videohelp.com/topic360761.html#1916479
i ran the checker, it shows dxva1 under the graphic card info and the ModeH264 with no FGT, however it does not show dxva under the mpc Video decoder? Does this help anyone work out the problem?
MPC-HC, MKV and memory problem
By Docoptik in forum Software PlayingReplies: 7Last Post: 18th Mar 2012, 21:40 -
No audio in MKV files when using MPC.
By ohnoeee in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2011, 03:04 -
How to take screenshot of MKV using MPC (with subtitle)
By dominator007 in forum SubtitleReplies: 4Last Post: 3rd Mar 2011, 02:29 -
.mkv subtitles in MPC
By andreyi in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 15:05 -
MPC playback problem
By ecc in forum Software PlayingReplies: 1Last Post: 14th Jun 2007, 11:24
