VideoHelp.com Forum
  1. I've gotten a few x264 (h264) media files which are 4.11GB in size and after using an (.exe) which converts it to AVCHD, it creates am (.iso) to an exact 4.3GB file.
    I would like to know, if I grab a mkv how would I determine if it will fit on a DVD9 disc after using tsmuxer? I've seen alot of 1080p mkv's which are about 7.8-8.1GB... Would it be safe to assume after converting it, it should still be under a DVD9 size?
    Maybe a calculator or something? I already know all about converting the audio profile to 4.1. Any ideas thanks?
  2. You don't need to convert (perhaps lossy) MKV, just unpack the contents with MKVtoolnix or MKVEXtractGUI, and mux files to BR/AVCHD disc with TSMuxer. You can remux MKV to BR/AVCHD directly in TSMuxer as well.
    Demuxed files size should be almost identical with source MKV as h264 and audio (AC3 or MP2) are already heavy compressed. I didn't test how MKV stores LPCM, if it compress much or not.
  3. Always Watching guns1inger's Avatar
    I would not assume. There is a lot of overhead (a surprising amount) in the M2TS and AVCHD formats. Yes, the demxued files should total around the same size as the source mkv (smaller if there is a lot of extraneous crap in the mkv file), but the remuxed file might be up to 8% larger than the source.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Yes remuxed file(s) will be bigger as the packet size of M2TS is larger than MKV and TS.
  5. Member t0nee1's Avatar
    You can always use the 'Split & Cut' feature in TSmuxer,if it exceeds DVD9 size....Or maybe re-encode your audio using a lower bitrate and remux...
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
  1. Help with BD-P1500 and mkv via AVCHD
    By Syco54645 in forum DVD & Blu-ray Players
    Last Post: 10th Oct 2010, 06:12
  2. AVCHD to MKV 5.1 Ripping
    By amitabhbansal in forum Video Conversion
    Last Post: 3rd Oct 2010, 03:33
  3. Mkv avchd pointers
    By romanticwarrior in forum Authoring (Blu-ray)
    Last Post: 7th Sep 2010, 17:57
  4. ripping a dvd to mkv h264 filesize question
    By stackner in forum DVD Ripping
    Last Post: 16th Jan 2009, 17:13
  5. MeGui HDTV TS to x264 mkv filesize problem
    By thunder2008 in forum Video Conversion
    Last Post: 15th Jan 2009, 02:53
