VideoHelp.com Forum
  1. I plan on capturing analog VHS, 8mm and Hi8 tapes to my PC via DV/Firewire. From there, I want to make DVD's from the input. It seems my tool of choice may be FAVC and the excellent HCEnc encoder.
    In order to make things easy & consistent, are there some preferred generic scripts to use from within FAVC that will clean up most analog video without doing much damage? Something light is preferred in order to help with the compression.
    I don't need anything extravagant, but would like something simple that will help clean it up a bit during the encoding process. I may or may not use FAVC to actually author the DVD. I might use TMPGEnc DVD Author, so I plan on keeping the temp files from FAVC.
    Thank you.
  2. virtualdub / avisynth these are the tools to clean videos
    encoding / author is another business
    If Henc accept frameserved files, then you can encode with it directly i suppose
    TheMaster Rules ;)
  3. Yes, and I'm looking for advice on those scripts.
  4. Well if you are interested in avisynth scripts go here:
    http://forum.doom9.org/
    And i wish you good luck in advance
    You can have an idea of what can be done with avs scripts here for instance
    I stick to vdub personnally it's more intuitive
    TheMaster Rules ;)
  5. Always Watching guns1inger's Avatar
    Short answer - No.
    Every tape requires it's own treatment, and every person here has their own preferences for the type of results they want. Some like light denoising and little else. Some like it so smooth it looks like plastic. Some tapes have drop outs or tracking noise to remove. Some tapes need sharpening. Some can't be sharpened without increasing other artifacts. Everything needs to be treated on it's own merits.
    Just to give you an idea of what is out there, and the variety of opinions, have a read of this : http://forum.videohelp.com/topic345071.html and follow some of the links in it. And this is just for denoising.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  6. Member Soopafresh's Avatar
    The choice of denoiser depends on the visual characteristics of your source file. The following uses a function called Temporaldegrain (found at Doom9). Works great, runs at a blazing 3-5fps.
    tdegrain.avi
    If you want something that runs very fast and merely helps with space compression, look at a plugin called RemoveGrain . Slower but arguably better is Fft3dfilter . Again, it depends on your source.
    AutoMKV has a bunch of Avisynth plugins and functions which you can quickly sample to see the visual difference.
  1. Portable PAL analog (yes, analog!) television set
    By stuey123usa in forum Capturing
    Last Post: 22nd Jun 2009, 19:23
  2. Analog to DV Tape vs. Analog directly to computer
    By jlorelle in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 7th Sep 2008, 09:45
  3. What are your favorite nautilus scripts?
    By freebird73717 in forum Linux
    Last Post: 16th Feb 2008, 17:28
  4. Are these scripts right?
    By php111 in forum Newbie / General discussions
    Last Post: 21st Jan 2008, 17:10
  5. Scripts for Conversion
    By jwfc in forum Newbie / General discussions
    Last Post: 6th Nov 2007, 06:50
