I've mashed up the above to make small key frame rich mp4 files. From DV captured by either WinDV or Scenalyzer adding a bit of avisynth (LanczosResize and Converttoyv12)
Its worked nice for a few years. Now with the advent of these HDD camcorders I'm trying to work with MOD files. There probably is a more elegant solution of converting from MOD to the final mp4 files but I didn't make much headway there so I've been trying a brute force method of first converting the MOD to AVI then put it back in the original process.
I've tried (among hours of other things):
ffmpeg -i infile.MOD -f avi -r 29.97 -b 6000kb -mbd 2 -aic 3 -cmp 2 -subcmp 2 -an - g 4 -vcodec xvid outfile.avi
(I don't need audio) This creates a nice quality avi but when I run it through my x264/Mp4box mashup I get an mp4 file of zero length. Obviously I'm not gifted things ffmpeg.
On the otherhand I downloaded the "free" download of AVS Video Converter and using it to convert MOD to AVI I could then run my mashup and get the results I want. I have two problems with AVSVC. 1) for all the "free" download hype they then want to charge you to actually practically use it. (As an editorial I'm happy that it could be worth what they are asking its just disingenuous to bait on a 'free' download as frankly all downloads are free but I digress...) and 2) the main reason is I'd like to run this from the command line not a graphical gui approach. Also my guess is that the avsvc folks have ffmpeg buried in there someplace anyway.
Any suggestions? -thx-
Thanks. I'll take a look but I do need something that I can run in batch mode.
feel free to check the application
BHHHDConvertToX, AutoMen, AutoMKV Developer
ffmpeg vs mp4box
By leandro in forum EditingReplies: 7Last Post: 21st Apr 2012, 09:16 -
VDub & AviSynth: Errors with ffmpeg and VBR audio streams
By klischee in forum Software PlayingReplies: 8Last Post: 20th Aug 2011, 19:13 -
Converting from MP4 (1280x720 x264 AAC) to AVI or WMV
By darkdestiny in forum Video ConversionReplies: 7Last Post: 6th Jun 2009, 22:33 -
commandline ffmpeg & x264 settings for Ipod 5.5
By halsboss in forum Video ConversionReplies: 4Last Post: 8th May 2008, 22:10 -
Having Problems converting h.264 mp4 to xvid using avisynth & vdubmod
By Rusty Shackleford in forum Video ConversionReplies: 3Last Post: 8th May 2007, 03:34
