Hi there,
I've been searching for a couple of hours now and ffmpegx is just working great for me. However, I do have a couple of VOB files, which I want to convert into one single mpeg-2 file, if that's possible. Everytime I use 'DVD' as a target format, I get multiple files and can't use these either.
My goal is to get the original VOB files into iDVD without any loss in quality. I just can't figure out the right options and settings in ffmpegx...
It would be great, if anyone could help.
Let me know if you need more information.
thanks a lot
EDIT: I do not want to create one mpeg2 file from multiple vob files. I'd rather create one mpeg2 file from one vob file (i.g. "1.vob" = "1.mpg"; "2.vob" = "2.mpg"; etc.)
Thread: VOB into one(!) mpeg2 file
If you want to turn individual VOB files into proper individual MPEG-2 files, then use MPEG Streamclip. Load the VOB, ignore the warning (no decoding needed for this), Save as MPEG.
I doubt it will help you get MPEG files into iDVD, though. The DV file format seems better suited for that.
Don't know if that solved your problem, but I use OSEX 0.0110a1 to do that. Works great, and is easy to use. The only bad feature is that the movie must be on a DVD.
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
How is done the sync between audio and video in a MPEG2-VOB file stream
By rmanal in forum EditingReplies: 0Last Post: 22nd Aug 2007, 09:33 -
Video Stutter / Skip when coverting from DVD to VOB / MPEG2 file
By afs_nj in forum MacReplies: 2Last Post: 13th Jul 2007, 15:39
Statistics
Newest guides
Latest tool updates
New media comments
