VideoHelp.com Forum
  1. Member wulf109's Avatar
    Are there any programs that can transcode an HD or BD to a smaller size either from the elementary stream or ripped directory? Leave it in it's native format(VC-1,etc.)
    You can reconvert h264 video using ripbot264. But you can't add back it to original blu-ray structure. Wait for blu-ray rebuilder.
  3. Member wulf109's Avatar
    I downloaded Ripbot. Is there anyway to control the size of the output file?
    Yep, you can set the size if you change to 2-pass encoding mode.
    Or try the BD Rebuilder beta and see how it works.
  5. Member wulf109's Avatar
    Tried BD Rebuilder but I get a Runtime error 9 when try to open a BD directory. Ripbot is incredibly slow. I'm running an E8400 wolfdale at 3.6 Ghz and it will take over 10 hours to convert a 100 minute movie.
  1. How is a Smaller File a Better One?
    By happydog500 in forum Capturing
    Last Post: 23rd May 2011, 20:50
  2. Replies: 27
    Last Post: 8th May 2010, 06:14
  3. .TS to a SMALLER file with nearly SAME QUALITY
    By Benygh in forum Video Conversion
    Last Post: 12th Dec 2009, 10:23
  4. Transcodeing Programs that use four cores?
    By wulf109 in forum DVD Ripping
    Last Post: 17th Nov 2009, 01:14
  5. how do i make a file smaller?
    By Sanosen in forum Newbie / General discussions
    Last Post: 28th Sep 2007, 22:57
