VideoHelp.com Forum
    Hi
    I have a Sony DVD Recorder model RDRGX700.
    I am trying to record from the recorder with some RW+ & -RW discs, but the recorder does not recognise the discs. error message says, 'Disc Error'. Normally i could go to the disc informaton section on the recorder to format the discs to work, when i get this message, but this is greyed out. These are on new discs, such as JVC, TDK. they work fine on the PC.
    would be grateful for any help.
    You won't know, until you ask
    Full format on the computer, then go back to the recorder.
    Lordsmurf
    Thanks for the tip. I can only do a 'quick format' on my software and cannot find full Format. I have Roxio Easy Mediar Creator. I see the option of a 'full erase' which i have tried, but still does not work. is this the same as a full format. can i do a full format via MS DOS prompt. if so, do you know the command.
  1. Evil Sony DVD Recorder Messes Up Discs
    By matthewjohn23 in forum DVD & Blu-ray Recorders
    Last Post: 21st Jun 2011, 21:00
  2. targa dvd/vhs recorder won't recognise dvd+rw discs.
    By steve6 in forum DVD & Blu-ray Recorders
    Last Post: 31st Jan 2011, 16:04
  3. DVD-recorder HDD-formatting
    By uno in forum DVD & Blu-ray Recorders
    Last Post: 20th Oct 2009, 08:34
  4. Lite-On A110 DVD recorder, problem with RW discs
    By Jack_Dante in forum DVD & Blu-ray Writers
    Last Post: 7th Apr 2009, 09:50
  5. Replies: 1
    Last Post: 2nd Feb 2008, 15:01
