Good Afternoon All,
I have a Samsung HT-BD2 R with Firmware 080724.01_XEF and I tried to make it Region free (at least for the DVD's).
The Hack Posted for the BD2 is for a HT-BD2 T and it didn't work for me.
All Hacks so far that I found posted on the web didn't really get me anywhere - tried ones for other BD players from Samsung as well but.....
I would appreciate if anyone would have an advise for me.
Also I was wondering about a a firmware upgrade - I found a newer version on the Australian website and I have asked Samsung if it would cause any issues to upgrade a device purchased in Germany with it but I have not received a answer yet.
Any advise - did anyone do this yet?
Thanx
Results 1 to 13 of 13
Thread: Samsung HT-BD2R
The newer Samsung drives appear to be locked and are not hackable.
Using firmware from a different region often isn't recommended as there may also be other changes either in hardware or software that you are not aware.Google is your Friend
Originally Posted by Krispy Kritter
Thanx Krispy Kritter,
that's what I already thought but.....Hope dies last :-)
I hope that someone will find a way soon to "hack" the Samsung devices to unlock the region restriction.
Thanx for the reply.
HSM
Same HC.Same problem. My version of firmware is: 080813.01_xef.
I`ve made some blu-ray discs (mkv files) but only 2 of them work. The rest of 6 don`t.
If someone know something pls reply.
10x
Knows something about what?Originally Posted by umbbra
The OP wanted region free, which isn't possible. You are having mkv playback issues which is a totally different issue. Your files obviously don't meet the requirements of the player. Compare the ones that work and the ones that don't and see what is different. And you should have started your own thread.Google is your Friend
Hmm can you pplease tell me how can I compare the movies. Is there a program or something?
10x
Try MediaInfo
There have been discussions here and at
http://www.doom9.net (in their Forums section)
that some H.264 encoding options don't work for playback on BluRay players after converting MKV files to BluRay. You'll have to look at a thread on AVCHD for more information. I don't have a BluRay player and I don't make AVCHD discs, so I can't help you.
hello all,
I also have a samsung HT-BD2R S/W:080813.01_XEF Region: B/02 (BD/DVD)
If you have news to change dvd region-free, I'm very interested.
Best regards.
Sam
On Dec. 26, 2008:Originally Posted by xenomesis
I'm sorry, but there is no hack for your player. No currently sold Samsung DVD player can be unlocked.Originally Posted by Krispy Kritter
Ok... its too bad...
thanks for your reply.
no updates on hack for this hc?
There are maybe 3 BluRay players in the world that can be unlocked only for DVD playback via a hack code. I've only heard of them being sold in Australia and New Zealand and Samsung didn't make any of them. Since the posts above we have had reports of a very small number of Samsung DVD players (NOT BluRay players) that actually can be unlocked, but I don't remember the model numbers.
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 10:45 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 16:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 22:06 -
Samsung HT-BD2R slow disk load times
By swheller in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Feb 2009, 11:26 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / HDTVReplies: 0Last Post: 7th Jun 2008, 01:42
