    I produce movies as 720x480 avi files for TV shows.
    Then I encode the movie to mpg2 using Adobe Media Encoder using MainConcept MPeg Video Codec into 720x480, 29.97 with highest quality video.
    I upload the mpeg video to Google Video, but the Google video quality is terrible!
    Please see:
    http://video.google.com/videoplay?do...79721460914392
    I'd appreciate all inputs to improve the video quality.
    Thanks in advance!
    --B11
  2. try encoding to h264 mp4 w/ aac audio. make the bitrate fairly high 5-10mbps 2 pass variable. see if that helps.
    Whatever you upload, Google video will resize it to 320x240. Use the "original size" option to see the small frame. That explains the low resolution. I don't think there's any way around the downscaling they do.
    Your opening credits have lots of macroblock artifacts because there is too much motion. That exploding star/plasma field will not compress well at the low bitrates Google uses. Aside from the low resolution, the rest of the video looked fairly good (what I saw anyway). You used static backgrounds, a tripod, smooth pans, all things that compress well.
    The video looked to me like it had been drop-field deinterlaced. I don't know if you did this or Google did it when it resized. If you can shoot progressive video there will be less jaggy artifacts on sharp, nearly horizontal edges.
  4. Member waefwaeefwaefw's Avatar
    Use YouTube instead, they now have "Watch in High Quality" and "Watch in HD".
  5. Member zoobie's Avatar
    they'll all follow suit...nobody wants to be left behind
    Author, Producer, Composer, Director - HC5, HV20, A1 Hi8 Mark II, FS-1 SLR
    12 Handcoded Personal Sites: HTML, PHP, JS, CSS - In Production: Busker Alley
  1. On screen Video download? And Google Sketchup video Help!
    By dooleygav in forum Newbie / General discussions
    Last Post: 12th Mar 2009, 10:41
  2. quality of video after Google upload?
    By carlton88 in forum Video Conversion
    Last Post: 27th Nov 2008, 00:57
  3. Replies: 35
    Last Post: 24th Sep 2008, 00:38
  4. Question about Google Video files and conversion to DVD
    By tomdkat in forum Newbie / General discussions
    Last Post: 10th Oct 2006, 21:48
  5. google video question
    By sdsumike619 in forum Video Conversion
    Last Post: 2nd Jul 2006, 19:39
Replay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
